Bosch washing machine
The machine fills with water a little bit then does nothing .
Let me know Bosch type or post a picture on my board if you like. Did you check the motor rotation on separately spin programm ?
Posted on Sep 09, 2009
What model and how old is it? Any lights on? will it drain or spin? Col
Posted on Sep 04, 2007
Hi I have a Bosch Avantixx6. On woolen wash it fills with water and then just sits there doing nothing????? Janet Bournemouth
My Bosch machine has very little drum movement on the woollen wash, I guess because woollens shouldn't be agitated too much.
Aug 15, 2016 | Bosch Washing Machines
Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
have a technician check it out as it may be a board problem
normally the fill level switch ,when the set water level is reached activates 2 things
it stops the water in and at the same time moves the program on to start the wash cycle
so it is either that switch or the program board
Aug 13, 2015 | Bosch Washing Machines
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
Filling with Water and then stops
replace the tub motor drive belt
Dec 03, 2013 | Whirlpool Washing Machines
My Bosch WFK2401 washer has stopped filling. The cycle will count down and the pump will run to drain (but nothing to drain!). I have checked the supply lines, there is water and the filter screens are...
I suspect the solenoid on the water input connection has failed, this is the unit that allows water into the machine , if you know a bit open the lid and you should see this just inside behind the cold water connection.
Oct 20, 2013 | Bosch WFK 2401
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
Jan 04, 2010 | Bosch Washing Machines
Bosch 2260 will fill and empty but nothing else
I Managed to fix my machine ( and Im a girl!!), had to turn the machine upside down to access the motor, took the belt off, and then the motor because you cant access both brushes easily without doing this, unclipped the cables, removed the old brushes and replaced, took about an hour, and the machine is running great again. It was much easier replacing the brushes on hotpoint machines, bosch dont make it easy, but I can complain , because this is the first problem I have had with the machine and its 8 years old
May 16, 2009 | Bosch Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
