Question about GE WSM2420T Top Load Stacked Washer / Dryer
Washer thumper my ge stack space saver WD thumps in the spin cycle. my freind replaced one of the springs because he said it was bad. but it still thumps with no clothes in it. also my heating element seems not to be working. how do i trouble shoot? are the springs needing adjustment or something? chaz
  • 240 Answers
The thumping could also be a belt issue if it has a flat spot in it, especially if its a Frigidare Hybrid GE. To get to the element, sorry to say it, but will have to remove the drum and front of machine to get to it. Ohm out all the thermostats and thermofuses first. If it has the round element behind the drum (which it should) check the heater wire for breaks. If its a true GE it will have two wires, Frigidare Hybrid will only have one. Good Luck!!! Jim
Posted on Sep 09, 2007
GE front load washer makes a loud slapping sound during the spin cycle and it sounds like something heavy is in the drum that keeps falling to the bottom of the drum when the spin cycle ends
You did not post the model number and that would be a must. However this sounds like the bearing or the pulley on the drum may have broken.
Dec 18, 2017 | GE Washing Machines
Tub broke loose from washer and is hitting the side. Can this be fixed, if so how much, can I do it myself
Had similar problem, finally found the problem. The tub is mounted with three bolts located just above the springs to the frame. One bolt was missing. Replaced the bolt. I had a terrible thump thump shaking the house spin cycle. Took the tub out and cleaned the filter too. Now the spin cycle works like it should and the tub drains faster too. This filter is a good spot to find a lost diamond. Or in my case a few sequins.
Dec 01, 2010 | GE Washing Machines
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Burning belts
try taking a flashlight and looking very closely at the holes in the tub with a flashgoht to see if a foreign object such as a nail or screw has fallen through one of the holes in the tub and jamming it try to rotate the tub by hand and let me know
Jan 19, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Washer thumps when in spin.
Open the service panel and look for a loose spring or a malfunction shock absorber.Replace the deffective one or return it to place. Regarding the heating element- check with a multi-meter for 115/220V on its tags. In case you can read 115/220V you should replce it. If you can't read it,your problem is not the heating element. Let me know if you need for further assistance. Good luck!
Sep 03, 2007 | GE WSM2420T Top Load Stacked Washer /...
GE WSM2420T Top Load Stacked Washer / Dryer Logo
126 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
