Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd62 door hinge
Have a new door hinge and got the door off but how do you remove replace the hinge - do you have to separate the door and if so any tips on how to do it without breaking the lugs?
  • carola Nov 09, 2007
    I have taken out the three screws on the door (2 nuts by the hinge bearing and 1 screw by the door lock) but still it won't split into 2 halves. Don't want to force it incase I break anything. any suggestions?
    New Friend:
All that has been said,has not rave-lance to the Simpson Colombo stove.
Nothing was broken.
After leaning on the stove door and cleaning the inside I noticed the door sagged sightly to the right, when I had finished.
When trying to even this up the hole door came out off it's seating.
The side that had sagged I noticed of of the little clip things was not in place and had not been in place for quite some time.
This clip was united with the bit above which I think is the locking arm and spring of the hole door.
It's these two small clips that stop me from closing the door.
(I think some how they have two purposes,one had been mentioned above the other I'm not sure).
Or once the door is seated in place on the stove are these clips things pushed of some how.
If so how?.
As these two clips are holding in the door hinges and the spring thing pull's against them?.
Posted on Jul 30, 2012
Same problem here. all say split 2 halfs but no one is saying how to split without breaking
Posted on Jul 05, 2008
  • 38 Answers
Yes u do have 2 split the door undo the screws and simply seperate the 2 halves and the 2 lugs that hold the hinge lift off get a small probe to push the broken lugs out of the fittings insert the new hinge put the 2 halves back 2gether screw the screws back up and remount the door 2 the cabinet jobs a gooden good luck
Posted on Sep 04, 2007
SOURCE:
How do I remove and replace the main oven door inner glass
partially open door and lift off the hinges . lay on a flat surface and remove the screws around the outer edge . separate the halves of the door carefully . take old glass out ,put in new and put it back together .
Jan 28, 2016 | Ovens
How to replace the assembly door for Delonghi Perfecta?
Take off the back panel by removing the two screws sliding it upward slightly then pulling it out.
Then remove the two screws holding the side panel in place(the side that the door hinge is on). Slide the panel backward and pull outward to remove.
Toward the front of the machine you'll see two screws that hold the digital display panel in place, remove those. This will allow you to push the display panel slightly forward and allow you access to the rod that secures the hinge.
With a needle nose players pull the rod upwards until itt completely separates from the hinge and door, the door will then just come right off.
To put the new door on just align it to the hinge and insert the rod from the top and continue to reverse the process you used to take it apart.
Sep 30, 2013 | DeLonghi Coffee Makers & Espresso Machines
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Kitchen aid khms147hss0 microwave - handle broke and gray plastic ( has 3 screws) on perimeter of door itself cracked - was going to replace complete door - how do you replace the complete door - remove...
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Fixing of door hinge?
undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Aug 14, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Goldstar Microwave MV1501w
Chances are the panels separate as shown in the photo I have attached below.
Panel replacement can usually be done without removing the door from the microwave.
In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges.
I generally do not advise removing the hinges from the microwave.
Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in.
Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
By the way, where did you get the part? I'm trying to find a good Goldstar / LG source to recommend.
Aug 16, 2007 | Goldstar MV-1155 Microwave Oven
Replacing battery door
I just did it 2 minutes ago, you have to remove all the screws around the body (7)and loosen or separate the body of the camera, then you remove the old cover at an angle, it comes out easily, then replace with the new one, making sure the little spring goes under the hinge... piece of cake... good luck.
Sep 03, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
435 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
