Question about Samsung (DXP47810JL) 5 Pack 8x DVD+R Storage Media
Burning trouble I tried to burn DVDs using this product and sometimes it would burn ok but often an error message ended the burn. However, the discs that burned ok will NOT play on a DVD player nor on my computer and it's saying "No disc" on both. I did this with several DVD burning programmes. I eventually trie to use on another computer through ROXIO disc copier which said "no recordable disc present" even thogh it was a DVD+R - the same message was for all discs I tried. pls help. My DVD re-writer says it supports all formats of DVDR & RW (plus, minus etc)
  • rx1123 Sep 19, 2007
    My DVD rewriter is brand new. I have now tried Kodak discs and it works just fine.
  • 54 Answers
The lens of your dvd writer might not be working properly anymore, i strongly recommend that you replace your writer with a new one.
Posted on Sep 18, 2007
  • dan coronado
    dan coronado Sep 20, 2007
    well if that's your case, i guess your dvd writer is choosey, with the brand of blank disk to be use.
SOURCE:
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Error message when trying to burn a disc in i Tunes
The problem is with your optical unit, (TSST****), it must be firmware-updated, which version of iTunes do you have?
Dec 09, 2017 | Apple iTunes
Burning dvds with realplayer
DVD discs come in two capacity sizes.
Single layer DVD have a capacity of 4.7 Gb
Dual layer DVD have a capacity of 8.5 Gb
Some DVD burners are single layer burners only and cannot burn dual layer discs.
The error message you are getting would indicate that the disc you are using is not large enough to copy all your program material.
Jan 25, 2009 | Ahead Software Nero 6 Ultra Edition...
Nero 7 write error
i think you have tried to write a cpoyrighted disc .
Jun 05, 2008 | Computers & Internet
Problem burning DVDs
This happened to me also. I fixed the problem by buying new DVD discs, sometimes the mac's rom doesnt like particular discs. Its a trial and error thing with which ones it will use. Make sure you are using the latest version of Roxio toast to burn with, also make sure your ROM is DVD-R.
If all this fails, it could be your writer in the rom. Try burning a CD, if that works it will be the above problems.
Try using discs with a GOLD BOTTOM, it seemed to work for me.
May 06, 2008 | Apple Power Mac G5 Desktop
Problems Burning DVD's
Ya didn't say what Operating System?... Ensure ya have all the correct "Settings" in the Burn software. Sometimes the actual type of DVD media can be an issue... some dvd's just don't "Like" some DVD's I have found... try the best brand ya can afford... if still no go.. try Alcohol 120% & CopyToDVD both use their "Own" "Drivers" and I have had great success.. where others have failed..
Aug 07, 2007 | Optorite DD1603 DVD±RW Dual Layer...
Has trouble reading discs (intermitant) when burning
There are two common causes for these kinds of problems: software doesn't match, or media doesn't match. also, there a lack of info in here. is drive capable of reading dvd's when it is used for other purposes? 1. are you sure you got the right firmware? check for updates on brand site or on google. 2. try using several types of media from diffrent brands. some drives cannot read specific media (for instance, sony drivers sometimes having trouble with JVC media). 3. the least common, but worst option by far is a hardware problem. if drive is bad, you should try and replace it in case your warrenty didnt expire.
Mar 21, 2006 | Lite On SOHW - 1633S (show1633sbk)...
Electronics - Others Logo
115 people viewed this question
Top Samsung Electronics - Others Experts
 Mike M
Mike M
Harrie
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
