Question about Konica Minolta magicolor 2300DL Laser Printer
RED over pictures
We have loved this printer for the past year. We recently replaced all the toners and for a while it printed fine. Now it prints with a red coating over the picture alm,ost like it is smeared on. We turned it off and back on - we took the toner out and blew inside - we let it set over night. i noticed af ew days ago that it was squeaking a little when it was printing. any help would be GREAT! Thanks.
  • 20 Answers
You need to remove all the toners and drum and vacuum the entire printer out. you need to clean the fuser very thoughly. You should take it out as well and clean it.
Posted on Sep 05, 2007
When i print red, i get pink
you might need to replace the laser cartrige, If its not that please tell me what you are trying to print (red picture or red text/writing)
Jun 08, 2012 | Samsung CLP320 AllInOne Laser Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Hl-1440 printer red, yellow lights keep flashing on and off prints ok what is it
Normally nothing to e alarmed about. As you said, it still appera to print okay. This flasing is a warning that your toner is low and will soon need to be replaced. If you recently replaced the toner artridge and know this not to be the case, print out a supplies status page from the onboard menu to see if it show low. Sometimes we are not aware of how much we have printed, hence the warning and the printer is usually right.
Apr 27, 2010 | Brother HL 1440 Laser Printer
My printer will not print. The red light comes
My printer will not print. The red light comes on, but there is no paper stuck anywhere. The toner light comes on, but when it did print yesterday, it looked fine. Please let me know what I need to check. Thank you,
Feb 15, 2010 | Brother HL 5140 Laser Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Pink lines and background on all prints
I have seen this recently on an HP 4250 and the red toner cartridge was at fault. Can you replace it and try to print again?
Jan 14, 2009 | HP LaserJet 4650 Color Printer
Can't print
no other lights if you hold start/go button then replace toner with Gen New one
Oct 18, 2007 | Brother HL 5140 Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
117 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
