I have a 21" Konka television that is 20 months old. Model K2166EZ. When i turned it on the other morning, the picture was shrunk and eventually turned off. it then did not turn on again until later that day. it struggled to turn on, but eventually came on. after a while however the picture will distort and shrink and eventually there will be no picture at all. i try to turn the TV back on with the remote but it wont turn on. if i leave it for a while i can turn it back on but soon after the same will happen. what is the problem? is it easy to fix? and will it be expensive? Thank you for your help. tjwis.
try to resoldered small parts inside, go to power section hot and cold! resoldered it.. then go to jungle ic resoldered all pin of them, and other small parts around at the IC.
I'm connecting a DVD player to the 32A43 and the player is asking for a resolution setting. I'll be...
(More)
I'm connecting a DVD player to the 32A43 and the player is asking for a resolution setting. I'll be using the component three connector and two audio connector. The player lists 480I/576I,480P/576P, 720P,1080I and 1080P. The manual does not list I or P ratings. I elieve it was printed bfore the ratings were establishd. What setting should I use for the 32AF43
My Sanyo DS31590 turns on but when it turns on the screen ratio is in 16:9? How do i get it to full...
(More)
My Sanyo DS31590 turns on but when it turns on the screen ratio is in 16:9? How do i get it to full screen????
