Toshiba 32A10 Sound but no Picture, Red Light Blinking
Hello, My tv has had this problem for several months now. When you turn the tv on you (usually) get sound right away and always no picture. The red light blinks while there is no picture and the picture comes on anywhere from 20 minutes to hours later(you can't predict when it will work). If you slap the side of the tv, the picture at least comes on momentarily ... and usually you can get the picture to stay on after doing this enough times. Any ideas on what is wrong and how to fix it? TIA
  • jamis1677 Sep 11, 2007
    Thanks for the advice. I finally found the right joint! I didn't see any cracks in the joints, so it was just a methodical touch up. I concentrated on the areas with heat sinks and also touched up the vertical ic too. I added a bit of new solder to each joint and fired up the tv after each section to see when I was done. It's on now and working normally.
    Thanks again!
  • 398 Answers
Your set has cracked solder joints, most likely on one of the small regulator transistors on the main board, with its own little heat sink. I have seen that many, many times, and it is a very simple thing to correct. Loose solder joints on the vertical output IC can cause no picture too, but it is usually those regulators that cause the problem. The set needs to have those regulators, the vertical output IC and all other major components resoldered and the set will play fine. If you do not have experience resoldering small parts on PC boards, allow a qualified tech to handle it for you.
Posted on Sep 05, 2007
  • 790 Answers
Try to check the heater supply,resoldered small parts and other major components. or check PCB crack board.
Posted on Sep 06, 2007
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
No picture, no sound
we need a request on what the blinking red light means on your model number and manufacturer of TV, we can then try to see what the blinking light means,(although it doesn't sound good) You ca always unplug the DVR and see if there is a change, then you would know it was the DVR
Thanks for the rating
Apr 12, 2009 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Dec 06, 2007 | Toshiba TP50H50 50" Rear Projection...
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
