Question about Toshiba 30HF83 30" TV
Tuning programmes on Toshiba 30HF83 30" TV Problem
I want to tune the channels on my Toshiba 30HF83 30" TV. Once i go to auto tune,it scans from 21 to 66 leaving 1 to 20.How can i make it to scan from 1
    Genius:
  • 1,139 Answers
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Posted on Sep 03, 2007
SOURCE:
What is digital auto tuning
Auto tuning AKA also known as auto scan..
This procedure is usually done when your TV is new or relocate to get the all channels available on your place..
Go to menu then find auto scan then press enter..Please complete 100% scan for best results..
Jan 05, 2012 | Sony KDL40EX600 TV
Tuning problem KV-21CL10
try to setting your tv in menu! and you can see the menu has air cable tv mode then select the ADD or ERASE mode! you select all channels to ADD mode! or you can auto search the program!
Oct 06, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
Jun 18, 2011 | Sony Televison & Video
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Toshiba 2141tb tuning
there is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
Mar 03, 2008 | Televison & Video
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 30HF83 30" TV Logo
378 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
