Question about Wharfedale DVD-M3 DVD Player
Wharfedale dvdrhd400 dvd recorder with 80gb hard disk drive
I cannot seem to record anything that is on my hard drive to a recordable dvd. Any ideas? Thanks.
  • 1 more comment
  • Anonymous Nov 01, 2007
    cannot dub to dvd
  • bommaz Oct 04, 2008
    I have followed the steps as i have the same problem but nothing go's to the DVD, just a blank recording to the hard drive and on another attempt nothing at all.
    Can the timeslip be turned off as i think this ma have something to do with it
  • Anonymous Mar 12, 2014
    My wharfedale dvd recorder won't turn on?
Use the playlist add '+' button continue to step 3
Posted on Mar 14, 2008
The "+" is the 4th button down on the right, part of the playlist buttons.
Posted on Apr 02, 2008
There is no "ADD" button on the remote....
Posted on Jan 19, 2008
1. Place a blank DVD in the tray.
2. Go to the HDD contents list.
Press the ADD button on your remote to select the files to transfer. At the top of the screen you should see the amount of space remaining on the DVD.
3. Press the REC/DUB button to start recording.
4. Once finished, go the DVD contents list. Press the UP button to go to the topmost screen. Press the RIGHT button to get the menu and select FINALISE to close the DVD.
Posted on Jan 15, 2008
Wharfedale 80GB DVD HDD Recorder DVDRHD400 USER
remote not operating, unit working otherwise, h/d not full, dvd's play ok
Oct 26, 2009 | Televison & Video
What are the correct connections for a wharfedale 80GB hard disk drive with freeview to a wharfedale digital TV with freeview and a dawoe video recorder?
Hey matt here, From memory I think it tv- video via scart and then scart or avr to HD. Hope this helps. Matt. Please Rate me
Dec 31, 2008 | Televison & Video
WHARFEDALE DVDRHD400
when you have split and seperated the part of the viceo you want to put onto a dvd, highlight it on the list of recordings and press the blue "playlist +" button on the remote. This will have added the recording onto the list of items to be recorded to dvd. Now press the red "RECORD/DUB" button. This will then record the file to the disc.
When y ou are notified that the process is complete,you will need to finalise the disc in order for it to be playable on other machines.
While the DVD is still in the drive uses the blue "function" button, and select DVD.
Shortly a list of titles on the DVD you have recorded will appear. Press the "UP" arrow on the remote once and a new menu will appear. One of the options here is to finalize disc. hilght this option and click the "RIGHT" arrow once - press "select" to finalise the disc.
Aug 30, 2008 | Wharfedale DVD-M3 DVD Player
How do i access the Hard Drive out of a Wharfedale DVDR24HD160F 160GB HDD DVD Recorder
hmm...similar problem here. i've taken the hdd out and plugged it in to the ide port inside my pc. The problem is it's the wrong file system. Your pc will not see it. It is however just a normal hdd so you can re-partition it and give it a new file systm ie ntfs but you lose all the data :(. that's as far as i've got, hope it helps someone.
Apr 06, 2008 | Wharfedale Televison & Video
Wharfedale dvdr24hd160 - Segment or split hard drive recordings
Wharfedale dvdr24hd160 I can not get the set up display on TV i have just the sound...!  Would you please help me. Thanks, Moon
Jan 14, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Wharfdale DVDRHD400 dvd recorder with 80gb hard drive
Sounds like if you are getting the right Video and not audio then the audio are hooked in wrong. Unless you are on SAP (Second audio program) in this case take it off of Sap. If you are getting the sound that you are looking at once you change channels to view another program, then it should be easy. Just change audio jacks back to AV1, 2, 3 etc depending on which one you are using. Hope this helps!
Dec 03, 2007 | Wharfedale DVD-M3 DVD Player
This tv has inbuilt freeview, how do i use a dvd recorder to record off it?
The Wharfdale Machine that has Freeview has an F on the end ie vdrhd400f. It may be yours is an analogue version. Always possible that you can use the TV as an output via a scart to record what you are watchin
Jul 14, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Wharfedale DVD-M3 DVD Player Logo
423 people viewed this question
Top Wharfedale Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Robert Rankin
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
