The two things you need to look at is the screens on the inlet of the washer, thes can get plugged with sediment and block water flow, take the hoses off the machine and look for the screens, either in the hose or water inlet connection. Second is the inlet valve, AI will include a couple of pictures of this. If you have an ohm meter all you have to do is check for continuity across the valve, if there is none the valve is bad and needs replaced.
The control panel lifts off by removing two phillips screws on the back of the control panel. The panel then flips over. The picture below shows what it looks like with the control panel removed
The inlet valve is on the left.
Not shown above are Power Control and Pressure Sensing Module, which plugs into the water inlet valve nipple, and the tech sheet, which you'll find folded up to the left of the water inlet valve. The tech sheet gives detailed instructions for entering diagnostic mode and interpreting the binary diagnostic code generated by the LED display on the control panel touch pad. anew inlet will look like this.
or very similar, depending on the model.
