Question about HP Pavilion zd8000 Notebook
Zd8256ea heating problems
Hi. I have overheating problems with my laptop. All fans are working, but laptop still overheats and shuts down regullary. Thanks for reply.
  • mrewired Sep 04, 2007
    Did that allready .. didn't help but thanks.
    I even opened notebook and cleared as much dust as i could .. practically all of it. I used a dust cleaner and was clearing all arround the fans. I'm thinking off compressor now .. blowin it a bit .. but i'm affraid i could damage fans.
  • 65 Answers
On many overheating problems we tell our customers to shut off the laptop, place a fairly strong vacuum cleaner flush against the bottom grill and hold it there for about 30 seconds. This sucks out a strip of dust that gathers on the cooling grid over time.
Posted on Sep 03, 2007
  • 60 Answers
If your comfortable with disassembling the machine then i suggest you Clean the CPU, HSF and apply some clean Silicone. Also there are fan controllers available for download which will force the fans to full speed. Failing all of that you can buy Antec or similar Notebook coller fan which sits underneath it with a large quiet fan to keep it cool.
Posted on Sep 04, 2007
SOURCE:
My computer will keep cutting off it mainly do it when im on netflix i thinking it got somethin to do with my shockwave
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 05, 2013 | Toshiba Computers & Internet
Tip
How to stop over heating laptops or computers.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
The most common cause of laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your laptop. This causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just Hot. Laptops get hot. It's what they do. However, if your laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link...
laptop over heating Google Search
on Oct 24, 2017 | Computers & Internet
Compaq Presario 1700T overheats and shuts down
Mar 26, 2013 | HP Compaq Presario 1700T Notebook
Overheat and shutdown hp mini laptop
Mar 06, 2013 | HP Mini 1000 Netbook
Lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
My laptop keeps turning off
Apr 29, 2012 | Computers & Internet
My laptop's fan isn't working so my laptop shuts down on its own every nw and then which i guess is due to overheating.what should i do to repair this problem?
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 19, 2012 | Acer Aspire 3680 Laptop
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
Toshiba satelite P105 laptop pc problem: overheats and shuts down automatically. while in use. What are the causes of overheating?
Normal 0 When a CPU chip overheats it shuts down (thermal overload) and won't boot up again until it has cooled down. If this problem is not fixed, then eventually the CPU chip will fail. This fault is either a faulty fan or the fan and heat sink assembly is clogged with dust. Please click on this link and follow my instructions to fix :-
http://www.fixya.com/support/r5959377-overheating_computer
Oct 16, 2010 | Toshiba Computers & Internet
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
HP Pavilion zd8000 Notebook Logo
265 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
