Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I don't know why the water comes out
All the water comes our once the cycle is finished what is the problem?
    Problem Solver:
  • 3 Answers
For long is the problem exist ?
Posted on Sep 03, 2007
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
Water doesnt seem to penetrate all cloths and clean light indicator does not come on when done
Has a bad water pump is the wash problem and light not coming on"done" is because it knows how much water the unit uses and there fore it knows it did not "finish" a correct wash cycle, therefor will not light up.
Sep 21, 2010 | Maytag EPIC MFW9700S Front Load Washer
Runs slow
There is a quick and inexpensive solution to the problem. Household vinegar. Pour about one cup vinegar into water reservoir, replace filter basket without filter allow it to cycle through. After it has finished brewing, you may repeat with another cup of vinegar. Once you are finished running the cycle with vinegar, fill water reservoir with water and cycle through. Be sure to run water through machine at least twice to rinse out all the sediment and or vinegar. Works everytime my coffee maker starts running slow.
Jun 17, 2010 | Cuisinart DCC-1200 Coffee Maker
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
kenmore dishwaher mod. 363.14482100 lower spray arm
wont operate on its cycle and dishes are staying soapy
after dishes done.
Aug 04, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
