The machine has worked fine for a couple years, and has recently been decalcified using vinegar. Now the flow of coffee has slowed to a dribble -- which could be the grind this time from the coffee store -- but also the steam does not seem to be as strong and the milk gets slightly bubbly but not frothy. Also, coffee is not as hot as it had been.
-   i ran through the vinegar and noticed a bunch of manganese and iron scale coming out with the rinse water. presently i am using saeco descaling tablets to clean out the machine. however, i find that it overheats and stops pumping after about 500mL of liquid. i just run some thorugh, stop and let it soak/work. then turn it on again to run more though or rinse water.
i am on my second descaling tablet, and rinse. i will let you know if it works out for us-   cinnamon_g
the little part were the cofee comes out from is clogged and the water and coffe comes out of the...
(More)
the little part were the cofee comes out from is clogged and the water and coffe comes out of the sides what can I do?
