Bose Acoustimass 5 III System Logo
A
Anonymous Posted on Aug 08, 2013
Bose acoustimass 5 series 3 connected to a marantz 1403 reciever doesnt sound good with music. bad match or just configuration problems?
5 Related Answers
Anonymous
  • Posted on May 08, 2009
SOURCE: Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
mismis
  • 21 Answers
  • Posted on May 12, 2009
SOURCE: Can Bose acoustimass 3 series II run on 12v????
no you can't because of the balanced powersupply the amps need + 0volt -, use a 12/220volt converter.
chears
Suraido
Gilbert Labont?
  • 195 Answers
  • Posted on Jul 07, 2009
SOURCE: Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
ram_samsung
  • 9 Answers
  • Posted on Sep 04, 2009
SOURCE: How to get good output and effect out of Bose
see the user manual and set the speakers at proper spacing and direction
Anonymous
  • 87 Answers
  • Posted on Oct 28, 2009
SOURCE: How do I connect my Acoustimass® 5 Series III
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Sir my speaker bose 301 series v and i connect to amplifier pioneer 5 x130 watts.also i have center speaker.bose vcs10.is this compatible to good music and movie....
If they're all Bose 301-5's then you have the rare instance of matching speakers all around, so when sounds move around the room in a movie they don't change. I'm envious because even though I have Bose 901's (front) and 301's I don't have that exact match you have. The 301 sound is very good to my ears.
I assume you have them all set as LARGE speakers in the Pioneer, since they are capable of good bass and the parameter is more about Bass response than actual size.
If you added a subwoofer (which you may not need) you might fill in the lowest bass and effects channel.
1helpful
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
1helpful
2answers
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
1helpful
Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
1helpful
Bose speaker connection
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
6helpful
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
