Question about Fuji FinePix S5000 Digital Camera
Flash button won't select mode.
Hi everyone, I just inherited a Fuji S5000 in great condition and love it apart from one thing...I can't get the flash button to work. I've followed the instruction manual, selected AUTO but the button just won't select any flash setting. I know the button itself is working because I can use it to navigate through the setup menu but in normal photography mode it doesn't do a thing. Any advice would be welcome, many thanks.
    Champion:
  • 217 Answers
You cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
Posted on Sep 08, 2007
SOURCE:
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
The flash is not working anymore. how can i replace it?
Hi, Check your setting for when you take photo's inside or outside. In dark areas the flash should come on. Check and /or replace batteries. Good luck.
Take a picture in a dark room and see if flash comes on.
Jul 30, 2011 | Fuji FinePix S5000 Digital Camera
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    My camera is fuji finepix S9500 and i like it very much, pls some one help me to resolve one problem i'm facing is how to activate flash(built-in) while we photograph images opposite to sunlight?
    Don`t own this model Fuji but on my F30 you find the flash symbol (lightning bolt) on rear buttons or internal menu & choose forced flash & then flash fires everytime even in daylight
    Aug 12, 2010 | Fuji FinePix S5000 Digital Camera
    I have a Fuji S5500 Digital camera , but the flash of the camera is not working, I am living in india in Kerala, where is the service centre in kerala.
    Look in the menus and make sure the flash is in the correct mode before taking it in for repair. Also check the batteries are up to charging the flash up.
    Aug 10, 2010 | Fuji FinePix S5000 Digital Camera
    Pictures with a flash are way overexposed. It just started this so I am sure there is something wrong with the flash. Pictures without a flash are fine
    My Fuji has started doing the same thing!
    The only way I can get a reasonably exposed photo is to place a piece of white paper in front of the flash to act as a diffuser.
    Any info you can find out would be appreciated...even if to know that this is a permanent situation.
    Still takes GREAT outdoor and moon shots!
    Jul 16, 2010 | Fuji FinePix S5000 Digital Camera
    How do you turn off the flash on samsung sl202
    When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
    Oct 24, 2009 | Samsung SL202 Digital Camera
    Fuji s5000 overexposing pictures
    try setting it to auto mode and see if it is ok
    otherwise
    they are not over exposed actually they have CCD HR problem ur CCD is having fault as 1000's have the same fault u will get pink shades in white and then later it will stop working u have to arrange for ccd change go to fuji service centre
    Feb 19, 2009 | Fuji FinePix S5000 Digital Camera
    Flash problem
    Same here. Any flash picture comes out nearly bleached out. Started from one picture being fine to the next being white. I'm very frustrated because I love this camera. I have a Digi Rebel and prefer my Fuji 5000! Anyone have any ideas?
    Dec 17, 2007 | Fuji FinePix S5000 Digital Camera
    Flash
    Sounds like the bulb might be a gonner. Can you hear it charge when you turn it on flash mode?
    Nov 26, 2007 | Fuji FinePix S5000 Digital Camera
    Fuji FinePix S5000 Digital Camera Logo
    90 people viewed this question
    Top Fuji Cameras Experts
    Ekse
    Steven Wander
    Steven Wander
    Azam Ali
    Level 1 Expert
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
