Question about Microsoft Office Standard for PC
Convert String to Nmuneric
Assume "2" is stored as string how to convert to numeric 2
  • Saiprasad Nov 21, 2007
    Its not Working
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Hi Saiprasad, Tough day huh?! :-) Try the following: Suppose "2" is in cell "A1" Type: =value(a1). Let me know if this helped and please rate my solution. Best, D.
Posted on Sep 03, 2007
How to write a program to translate english text to binary string and write a program to do inverse 27 = . , 28 = , 29= ? 30 = . 31=
to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
here's some links that might be of interest to you.
Visual FoxPro VFP CTOBIN and BINTOC Functions Equivalent In Net The Most Accurate and Reliable Source Code Converters
Feb 06, 2015 | Microsoft Visual Studio 6 6.0 Professional...
Argument checking!
The calculator does have several error message concerning the argument. For the Request( command the syntax is
Request(Message, VarName)
What you type is stored as a string. It is only after you try to convert it to a value that the calculator looks at its content.
Here is an example where the variable VarName is x
Request ("Variable x", x)
I enter a complex number, manipulate it mildly with no apparent problem. However when I try to convert it to a numerical expression, and store it in the variable x, y, theta, I get a message Error non-real result.
Jan 13, 2014 | Texas Instruments Voyage 200 Calculator
Code to convert number to string in SQL
You could use a combination of the CONVERT and CAST functions to cast the number as a money type, then convert it to a varchar, and then strip off the decimal point and 2 0's at the end: DECLARE @test int SELECT @test = 12345 SELECT REPLACE(CONVERT(varchar(50), CAST(@test AS money), 1),'.00','')
Regards, ploysandy
Jun 26, 2010 | Computers & Internet
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
MyNumber = ""
End If
Count = Count + 1
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
1. Write a C program that converts a string
Here is a website that should be helpful...
Mar 17, 2010 | Office Equipment & Supplies
In the programs I have made when I use the Request enter a integer, I always have to press the alpha button before entering a # in the field when running the program, is their a way to program a request...
The syntax of the command is as follows
:Request Message, VarName
where Message is a character string containing the message that will be displayed as a prompt, and VarName is the name of the string variable where the input will be stored.
If you want to input a numerical value you must convert it from character string to a numerical value (I know, it is like splitting hair but string 123456 is not the same as number 123456)
You convert from string to numerical value with the expr() command.
:Request "Value of a? ", s
:expr(s) --> a
That should do it.
Hope it helps.
Oct 15, 2009 | Texas Instruments TI-89 Calculator
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Solution for converting image(jpeg,.bmp) to string
hi prem,
i really cant answer your question but im hopeful that maybe this link will help you in your troubles.
thanks for using fixya
Mar 30, 2008 | Computers & Internet
Selecting only Numeric part of a database feild
Well, one solution is to fetch the whole data, including the non-numeric part, and then convert that into a number. Most programming languages strips off the non-numeric part of a string when converting into a number. For example, converting '24Michell' to a number will result into '24'. Consult your programming manual on how to convert a string into a number.
Oct 01, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft Office Standard for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
