Question about Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW Drive - 16X DVD+R - 16X DVD-R - 8x Dual Layer +/-Support - Retail ... (LTNSHM165H6S) Burner
Driver cannot start
I can put any cd or dvd in and absolutely nothing will happen. I go to My Computer and it doesn't even show the drive. through devise manager I can find it but it says "Driver Cannot Start (code 10)" I have clicked on the "check for solutions" button but it does no good. Should I uninstall the driver and try to reinstall it- will that work? this is the driver that came in my HP
  • Lite On Master
  • 12,061 Answers
First ensure ya DVD is OK in BIOS, IE: Ensure the Drive Table shows it "Active". Otherwise the drive is faulty & must be replaced. If OK, Then Boot, & go to Device Manager & right click the DVD & "Uninstall Driver" when asked if you want to totally removal/remove all files say Yes. Then close down & turn power off, then open PC & disconnect the DVD drives Power & Data Cable.. then reboot.. Get to the desktop and then shutdown & Turn the PC OFF, then reconnect Power & Cable, restart PC. Windows should "Detect" the "New" DVD and pretty much "Just work".. it may ask for "Drivers" if you have got them, point it in the right direction of the Driver files & install If windows doesn't "Detect" & install driver & and pretty much "just work" after this.. then again your device is faulty. If it's not working, then ya gotta replace the DVD with a new one, when doing so, just do as above to install.. Connect Power & then the Data Cable, etc.. etc.. and ya should be all good.. as usually if it's a good one.. they just work..
Posted on Sep 03, 2007
SOURCE:
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Dvd door doesn't open
if there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
hope this helps
Sep 24, 2012 | Computers & Internet
My laptop (acer) doesn't play DVD movies or audio CDs what can I do to fix it?
Eject the DVD tray and clean the laser lens with a piece of cotton.
Enter to Setup Bios (Restart the PC and press " F2" key to entert BIOS setup and see if the DVD drive is show in device
restart
In windows..go to control panel
devide manager and look if They are a yelolow mark bnear the DVD drive
Click and UNINSTALL
Restart the PC.
If don´t work , may be the DVD drive is faiulre
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Computers & Internet
The CD/DVD drive doesn't work at all! It doesn't read Cds, DVDs, nothing. It doesn't even open or make noises or anything. It shows up on My Computer and Device Manager but doesn't do anything. I have...
make sure that the dvd is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 26, 2011 | HP Computers & Internet
When i put cds in it works when i put a dvd in i go to computer the drive shows nothing but when i put a blank dvd in it shows it but cant burn nothing to it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
Dec 27, 2010 | Lite On LH-18A1P DVD RW Dual Layer Burner
Need help instaling photo exploision deluxe 4.0 when i put the dvd in my driver.. it just says .. no **** in driver.. nothing happens!!! help !!
Do other CD work? If yes, you have a bad Photo Explosion CD.
If no, then you have a bad CD/DVD drive. You can get a new one for $30 if this is a desktop pc. If you have a laptop an external dvd drive would be the best option if you don't use the DVD drive very often.
Feb 28, 2010 | Computers & Internet
DVD CD ROM Problem
CD/DVD Drive Missing In My Computer
1. Go to Control Panel > System > "Click Hardware Tab" > Device Manager > IDE ATA / ATAPI Controllers > Right Click then uninstall
2. Reboot
3. If the problem is still their you will need to remove the upper and lower registry keys. You can do this by following this Microsoft Knowledge base article. http://support.microsoft.com/kb/314060
Sep 21, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Wont Recognize DVD drive
if its brand new go and get it checked by warranty.
Aug 19, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
-\&;-DREAMMAIL Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This DreamMail USA phone number is ranked #2 out of 2 because 7,728 DreamMail USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the DreamMail USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, DreamMail USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. DreamMail USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact DreamMail USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling DreamMail USA Calling DreamMail USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from DreamMail USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with DreamMail USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare DreamMail USA's phone numbers against each other. Contacting DreamMail USA in General While I8OO8280294 is DreamMail USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach DreamMail USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact DreamMail USA.
Oct 16, 2019 | Best Computers & Internet
-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }-\&;-Avg Customer Support Phone Number #{+ I:888*499*5520 }
Oct 16, 2019 | Computers & Internet
See all Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW Drive - Questions
Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW Drive - 16X DVD+R - 16X DVD-R - 8x Dual Layer +/-Support - Retail ... (LTNSHM165H6S) Burner Logo
91 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
