Question about Pioneer DEH-P690UB CD Player
Speakers dropping out & engine sounds
I have the above stereo running through a GM6200F 600W Amp. was fine till recently all speakers dropped out except the front left speaker and a loud whirring engine sound came through that speaker even with volume off. wierd thing is by turning volume right up the whole system starts working perfect but only for about 5min..
  • Anonymous Jul 09, 2008
    I just started having the same problem with mine . Had another radio hooked back up and all was fine. It is defenitely in the radio, but who fixes these I hav had it for about 3 months.
Sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Posted on Mar 28, 2008
6ya staff
SOURCE:
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the speakers....you should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
Red Power Protector light
Hi, the only way i can see the amp resets the stereo is that power is dropping. The amp should have its own wires directly to power/battery so as to not affect anything else.
On the protect, try to disconnet all the speakers, make sure the power is OK. If it appears to work, the there could be a problem with speakers/cables. Try a different speaker to see if it works. If the problem continues with speakers off, a different speaker etc, then there is a problem with the amp. Hope that helps
Jul 21, 2009 | Sony XM-2100GTX Car Audio Amplifier
Is my subwoofs or amp that's bad or even ground
If amp is stereo then remove one speaker at a time and check sound quality. Determine if it's one channel or both. If Mono, or bridged, then do same and determine if it's speakers or amp. If problem with both, then it may be amp, but without another set of subs or a scope to test, the possibility that both subs are blown remains. You should know if you pushed it real hard all the time till it clipped, or till the speakers were popping out of their cones, or do you use it within the rated limits, with the system tuned to prevent clipping. If you have been bumping it real hard, maybe suspect the subs. If the amp is acting normally otherwise.
Apr 05, 2009 | Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Signal to speakers periodically drops out
I can not tell for sure without seeing the unit; however, this often happens with stereo receivers when the contacts on the protection relay start to go bad. You can try to polish the contacts with emery cloth or a fiber brush but it is best to replace the relay if you can find one that will fit.
Jan 01, 2018 | DBX Driverack-Pa Eq/Speaker Control System...
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
Losing treble at higher volume
There are two things. First check the sound settings of the DVD player. It might be putting out a lower quality sound on the CD side of things.
Secondly try to determine if the speaker tweeters are working. Connect the speakers if you can to another sound source. If the speakers are good and the settings fine. Then you have a fault in the amp unit.
May 26, 2017 | AAD C-600i Main / Stereo Speaker
Pioneer DEH-P690UB CD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
