Question about DeLonghi IHF2 Heater
Gas supply keeps cutting out
Gas bottle is full, but heater keeps cutting out. is there a filter or something that needs cleaning?
  • Anonymous Mar 12, 2014
    When switched on lights and heater work then heater cuts out
Flame detector's given up, mercury pressure developed from flame heating a small bulb and capillary pipe keeps gas flowing, they seem to fail over time. Not developing enough pressure and thus giving regulator a false flame out reading. dilonghi call them analysers. No fix - fir replacement prt
Posted on Mar 26, 2010
I'd be checking what the operating gas pressure is correct - when it's operating, not when it's stopped or off. My suspicion is that the gas pressure is incorrect & the regulator needs adjusting, or that the gas bottle is simply too small for the heater & can't evaporate enough gas to keep it going. You really need a gas expert to advise on site. Regards, Greg (Aussie gasfitter - too far to do house calls)
Posted on Sep 10, 2007
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
How to clean gas heaters
Agas heater is a device that uses liquefied gas for heating. Since it isconnected to a gas source, cleaning it is quite easy. Keeping the gasheater in good condition by cleaning it from time to time is importantto prolong its durability. Cleaning the gas heater regularly is alsoimportant from a safety perspective, because deposits in the flue, oranywhere else in the device, can sometimes lead to problems.
  1. If the gas furnace is not running, the power could be disconnected, the motor overloaded, or the gas supply insufficient. Check each of these components individually, ensuring the gas heater has sufficient power and that the motor is running (you will be able to hear if it is running when it kicks on). Check the gas reserves tank to ensure there is gas in it. If these systems function properly and you are still having difficulty, your heater may need to be cleaned or repaired.
  2. Cleaning
  3. If your heater is not heating properly, dirt in the gas lines--and especially the burner ports--could be the cause of the problem. First,disconnect the lever that connects the gas supply to the appliance. The burner ports are the parts that distribute the gas supply into the heater. They have to be cleaned with the help of a toothbrush or flask cleaner. The part called the burner access panel, which is located at the tank's lower part, may also have to be replaced if there is a dirt build up. This piece can be purchased at your local home improvement store and replaced according to the directions on the package.Generally, this should be replaced every two years.
  4. Filter
  5. If your heater is turning on and off repeatedly this could be caused by dirt in the filter or lack of lubrication in the motor or blower. Check your users manual to locate the filter (it is usually a large piece that slides in and out of your gas heater from the side), remove it after the gas has been turned off, and wipe off any excess dirt.Alternatively, you can replace the filter entirely rather inexpensively. Simply remove the filter, write down the model number and get a replacement from your local home improvement store.
on Dec 17, 2010 | Heating & Cooling
Kampa Calor. Why isn't it lighting?
sounds like the line from the gas bottle is air locked .keep trying to light whle holding the button down longer
Feb 11, 2016 | Heating & Cooling
How do I make my lawn mower run better?
Yes, clean the air filter if it's a foam , washable fliter. If it's not the washable kind , replace it. Also replace the gas filter if there's one on the engine. Buy a can or bottle of carburetor and fuel system cleaner and put it in the gas tank to clean the carburetor.
Jun 10, 2014 | Mtd 22" Yard Machine Push Mower
My heater keeps blinking and a code on the top says 11...also ..if i unplug the unit while i wait for it to get fixed does the pilot light go out?
There is no pilot light on this model. An 11 error code tells us that there is no gas supply to the heater. Could be a bad gas valve, dirty igniter, gas got shut off somehow, dirty burner, etc... All you can do is make sure the filter is clean, a technician will need to open it up. Sorry.
Apr 09, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a five year old Raypak 207A on my 500 gal spa. When I turn the unit on, the display shows: PV 1, then CFH, then SPK, then the burner ignites, then CFH again, then it displays the flame icon and...
CFH means "Call For Heat", and SPK is "Spark". It sounds like you are running out of gas.Propane tanks need to have 30% in the tank for a heater to run correctly,and after they are filled you must bleed the air out of the line.If you have Natural gas,the gas line may be too small to supply enough gas to keep it running. NOTE...gas pressure MUST be checked with the heater running.
Sep 28, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
My rinnai comes up with a code 11 when i try to start it. if i try it about ten times the main valve opens and runs fine. but untill that point it doesnt start. any ideas?
Mysolution relates only if you are on LPG/bottleg gas. I have had many problems with the gas regultor actually on the initial supply line near the bottles sticking. Error code 11 is usually simply a gas supply issue and not a fault with the heater itself. Just rule out that before you start messing with the heater itself. Causes inside the heater would be either gas valve (unlikely) or PCB. Both are not normally intermittent. Try running something else on gas if you have anything and then turn on the heater.
Sep 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We are getting luke warm water and the low gas alarm is sounding even though we have a full bottle of gas. My gas hob is working fine.
even though you have a full bottle it might not be the right bottle, you have to have a min 2lb for a water heater to work, take and have the bottle checked to make sure it is the right pressure tank
Apr 19, 2009 | Water Heaters
Pool heater Maintenance
Pool Heater Maintainance - Gas Pool Heater Gas heaters are the most common type of pool heaters being used presently. The gas heaters work on natural gas or propane tanks. The gas heaters are favorite hide out of spiders and other insects. It is recommended to regularly clean the spider webs and the debris off the heater. For it can clog off the burner openings. You can clean them manually or with the help of a vacuum cleaner as well. The most important thing about maintaining the gas pool heaters is to check the gas supply regularly. Check out the pipes to detect any leakages. You can easily detect the leakages using a soap solution. Prepare a liquid dish soap and warm water in the spray bottle. Now spray the solution on the pipe joints. If you find any bubbles emerging from the surface, you immediately need to repair the pipes. Never use the heater until the pipes are replaced or repaired by a qualified plumber. Pool Heater Maintainance - Electrical Pool Heater Electrical pool heaters are also getting popular these days. The heaters produce the heat with the help of heating elements. The element can get coated with certain minerals present in the atmosphere. This hampers the heating process. You can easily take it out and clean with a wire brush. Some elements get damaged beyond repair. You have to replace the element. Take along the old element with you while looking around for a new one in the market. It is absolutely vital to change the element otherwise it can send some current in the swimming pool. First of all, turn off the power supply to the heater to avoid any injuries. Open up the drain pipe and take out water from it. Fix the new element and test the heater by filling water in your swimming pool so that the heater can work to its full efficiency.
Aug 27, 2008 | Raypak DOOR ASSEMBLY
DeLonghi IHF2 Heater Logo
992 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
