Question about Freezers
LG Fridge freezer Ice formation
We are getting regular ice build up in the base of the freezer section, had the back panel out but couldnt see any problem. Believe from this forum that the cause could well be a blocked drain, I couldnt see a drain when I looked allthough I wasnt aware of what to look for then, where would the drain be located?, I dont know the model no off hand but it is approx 3 years old, has single doors.
  • 291 Answers
Below the evaputator coils should be some type of pan or drain system ... the drain most of the time is in the middle of the pan... it you see anything with ice defost should be NO ice in there .. can use hair dryer once defrosted u should look for some type of drain whole.. once u think u got drain open pour small amount of hot water down to help clean and test if drain is open
Posted on Sep 03, 2007
SOURCE:
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Freezers Logo
723 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
