Home | Haier | RTC1700 1700 Watts Toaster Oven with Con... | Slow to heat Haier Con...
Haier RTC1700 1700 Watts Toaster Oven with Convection Cooking
Problem for Haier RTC1700 1700 Watts Toaster Oven with Convection...
Slow to heat Haier Convection Oven
By ad_graph on Apr 04, 2009
The oven takes a long time to heat up. It is set on bake and has been turned on for 5 minutes and the heating elements is still not glowing. Why does it take so long to heat up. Is it because of the convection feature?
Best Solution
posted on Apr 05, 2009
Very Helpful)
cactus bob
Rank: Guru
Rating: 93%, 279 votes
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Haier RTC1700 1700 Watts
Questions and Unsolved Problems for Haier RTC1700 1700 Watts
Do you recommend Haier RTC1700 1700 Watts Toaster Oven with Convection Cooking?
Answer
Answer
I look for diagram circuit kitchen built in oven SMEG 210,can you help me?
Answer
Where can I find a timer knob. The back of mine broke off. Will it be a universal knob to fit other... (More)
Answer
hi my creda 5tcc cooker has broken the oven is not heating up and i think it tripped out my house... (More)
Answer
What tray do I use to cook frozen chicken nuggets in a infrawave toaster? Or do I just put them on a... (More)
Answer
does not heat at all. timer and rotisserie work.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier RTC1700 1700 Watts...:
Top Toaster Oven Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Toaster Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
