Question about Weather King 10AJA6001AH Air Conditioner
Weather King contact info
Our AC unit is not working, a local technician came and concluded we need to have the compressor replaced and he said it should still be under the original 10-year warranty. But I was not able to locate any contact/support phone number in the origianl installation guide (that's the only document I have related to the AC) we got from the builder when we moved in 5 year ago. Does anyone know how/who to contact (Weather King) in a situation like this?
  • 50 Answers
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Posted on Sep 03, 2007
Model 10AJB48A01. What are the specs for the motor starting capacitor?
it is either a 45/3 370vac or a 60/5 370vac depending on the compressor that's in the unit. if the unit serial number starts with 6936 it is the 45/3 if it starts with 6937 it is the 60/5
Jul 24, 2015 | Weather King Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
How do I find out if my unit is still under warranty?
All you need to do is copy down the model and serial number and call the local weather king rep or even a dealer and they can tell you. Most units have a minimum of 5 year compressor warranty and 1 year on parts. Many units have 10 year compressor warranty and 5 year parts. It would be worth your while to check. Hope this helps.
Jun 24, 2011 | Weather King 12AJA4801AH Air Conditioner
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
How much is a compresser for weather king ac unit
Be happy to help you and find an answer. Did your compressor burn out? What are the numbers on top of the compressor? How many BTU's or What is the the size? Tons of BTU's?
May 16, 2009 | Weather King 10AJA1801AH Air Conditioner
Condensate Drain
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Weather King 12AJA6001AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Warranty and repair
call the company that installed the unit first. if they wont pony up any reputable hvac service company can honor the warranty. the manufacturer will give him a free compressor and you will have to pay him labor to install it.
Jun 12, 2008 | Weather King 10AJA4801AH Air Conditioner
Warranty on compressor
The actual age of your unit can be determined by the serial number. Based on the age indicated there they can tell you if the warranty is still valid. Your local Rheem/weather king dealer can do this for you. Most compressor warranties are either 5 or 10 years. Good Luck!
Jun 11, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
413 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
acrman404a
Bill Long
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
