I was just recently given this tv and was told all it needed was a service call and had been working until recently.As soon as I got it home I discovered the 5amp fuse was blown and re-placed it but to no avail the same thing keeps happening when I replace the fuse,it blows out.
Hi! the picture has dropped about 6 inches and the green control does not go up also the picture...
(More)
Hi! the picture has dropped about 6 inches and the green control does not go up also the picture appears to be bend at the top
edge
GE 46gw945 52" Just moved from one house to another, tv was wrped in blankets and wraped in...
(More)
GE 46gw945 52" Just moved from one house to another, tv was wrped in blankets and wraped in sheet plastic, it rained however the unit was bone dry when I brought it home, went to turn it on and nothing, sbot s hslf hour later I hit the power and it came on and was working fine then the menu poped up, and mutted the sound. now when I hit the menu button it does nothing and when i use the chanell buttons the menu pops up instead of changing the channels.
I have Dish network and after they readjusted my dish the universal remote did not control the GE...
(More)
I have Dish network and after they readjusted my dish the universal remote did not control the GE TV. I tried all of their recommended codes and none of them work. Can you help?
the picture is distorted. the color is splitting from the image. red, green blue yellow is...
(More)
the picture is distorted. the color is splitting from the image. red, green blue yellow is separating from the picture/image. what parts would you need to order to fix the three different color problem with the ge 46gw945
posted by luckey777 on Apr 16, 2009 i have this model GE 46" projection tv that does not power...
(More)
posted by luckey777 on Apr 16, 2009 i have this model GE 46" projection tv that does not power on with either the remote or manually turning it on......the noise is a clicking from the back of the tv but nothing else happens....what is the likely problem? I have a similar problem. The power button flashes greed momentaRILY AND NOTHING.
