Question about Samsung Digimax S500 Digital Camera
The lense does not close in
I have been using model Digimax S500 for past one year. While out of India, the battery went low. The lense did not close in. I tried new batteries. But still the problem is not solved. I need a solution.
Although your solution did not work, I got a tip from it that there is a catch holding the lense assembly. I removed all the six screws on the four sides of camera; then removed the rear frame. With frame removed, I inserted the batteries and switched on. Then switched off. And WOW, the lense retracted. Thanks again for the tip.
Posted on Sep 03, 2007
  • 641 Answers
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
SOURCE:
I have a digimax s500/cyber530 When i turn the camara on all that happens is a loud bleeping .and the lense will not come out also it emediatly turns off
be sure battery is fully recharge, if it not replace it with the same rating. also check charger it may not operate well.
Feb 18, 2011 | Samsung Cameras
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
Is it the problems of batteries?
rechargable batteries are the way to go with a digital camera... mine just eats regular ones
Jan 03, 2009 | Samsung Digimax S500 Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
Camera problems
Turns out the brand new batteries I installed were dead.
Mar 18, 2008 | Samsung Digimax S500 Digital Camera
Samsung Camera mod DIGIMAX S500/Cyber 530
still that happens to me sometimes...this is when you need t o charge your battery over again fully....
Dec 28, 2007 | Samsung Digimax S500 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Frozen camera
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at [email protected] or im makaluso06
Jan 26, 2007 | Samsung Digimax S500 Digital Camera
Where to get a Samsung s500 usb cable
I can't imagine why in the world you would want to pay an inflated price for another proprietary USB cable. I haven't plugged a camera directly into my computer for years. The last time I did, it was balanced precariously while downloading pictures and got knocked off the table. The USB cable stopped its fall, but the jack in the body of the camera was twisted in the process and completely ruined. A much better option would be to head to your local Comp USA, Best Buy, Radio Shack, etc. and purchase a 9 in 1 card reader. It's a small block of plastic with several slots that will accept a wide variety of memory card formats that have been created over the years. With this single USB device you can read/transfer data from many different devices that you may own. The reader can stay attached to your computer all the time. You simply take the media card out of your camera and plug it into the reader whenever you want to download your pictures. Simple! As an added benefit, you can now make use of that pathetic 128 meg card that came with your camera. Write all your internet accounts, passwords, and other important info to it. Then hide it in a safe place (deposit box) in case of disaster.
Jan 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
