I have a Charmglow model HBL-15SDLP/M20 electric heater. The rocker switch went bad on it and I can't find a replacement part anywhere. The manufacturer said they can't get replacement parts. The part number is HCKD-044. Any suggestions
1,954 people viewed this problem
This solution has been voted best by the Fixya Commnunity
The switch itself is a (double pole single throw ) 15 amp 250 volt /20 amp 125 volt.You can buy any switch like that.The hard part is trying to find the same size to fit the hole in the heater.
Yeah same problem here with heater switch. Almost caused a fire in our house. After taking the unit apart to take out the switch we noticed the wires connecting to the fan switch were all black and melted! Be carefull with this heater!
They fan on our unit is making noises, does anyone have a unit that they have given up on?
pdees246 Same model #, same problem with the rocker switch. Luckily the switch is stuck on the on position, so we plug it in and then unplug when finished. Any suggestions for parts?
Nov 18, 2010
charles20572 fire issue throw it away
Feb 11, 2013
The built-in tip over switch cuts in automatically when the unit is tilted 30 degrees. if this was activated while...
Rocker switch for 600w and 900w combo is no good now, don't see a model # on the heater. Switch is a Defond DRH-2415 15a...
I NEED TO SEE A WIRING DIAGRAM FOR THE ROCKER SWITCH ON A MODEL 7000 LAKEWOOD OIL FILLED HEATER
I have a charmglow electric fireplace all switches light up but no heat and fake flames do not work. ideas?its on a...
My thermostat is broken and the unit won't work at all. Where can I get the new part?
I'm trying to find out how to access the pilot/thermocouple assembly so I can clean and continue...
should i check to see if the switch is bad then the motor ?
I have a Brivis 85 installed 2006 we seem to have a problem when the wall controller isn't talking to the unit...
William Worsley SAME SWITCH PROBLEM
Jan 27, 2013
Guest We purchased the same unit in the fall of 2008 and 2 months ago the fan power switch totally fried and almost caused a fire in our home. We are looking for another switch for the unit as well and have run into the same problem with the company not having any parts.
Apr 17, 2009
jtortoso Same problem here. I was going to try to find this switch, or one like it. Might as well give up huh.
Apr 12, 2009
