Question about HP iPAQ H5450 Pocket PC
Failing to power up.
Just bought the IPAQ 5450 from a garage sale and i was told it worked intermittently. Took it home and tried charging it with no indication showing that the unit was charging. If i do a reset i get a faint flicker on the screen and if i were to do a hard reset (holding power button and hitting soft reset)the screen flickers a couple of times and i get some orange flashing LEDS and then all blank again. Tried a new battery and got more flashing lights but no power up. Unsure as to how long the unit has not been charged. Help appreciated.
  • SINYSTER27 Nov 08, 2007
    WHEN I PUT MY IPAQ ON THE CRADLE ITS GOOD AND FUNCTIONAL BUT AS SOON AS I TAKE IT OFF THE CRADDLE IT TURNS OFF LIKE IF THE BATTERY WAS DEAD ILL APPRECIATE IF YOU CAN HELP ME
  • maxabigi Mar 18, 2008
    same model, same problem. Connected to charger, pc etc and the screen just flashes, no indication of charge. Can anyone help
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Posted on Feb 08, 2008
Hi I just got a 3150 iPAQ pocket PC at a garage sale. All I got though when I bought it was the pocket PC itself and the power adapter. I was told it would work when I plugged it in. All I get though,...
why not post to hp with this old thing, nobody uses. now.?
sure garage sale most are in the trash long ago.
buy used cell phone and end this misery?
find a manual, read it?
hp dont have hit now, this product is RETIRED
that leaves deep google lucky finds.
here ill google for you,
https://duckduckgo.com/?q=3150+iPAQ+manual&ia=products
i boycott google so... that.
or ask here, at HP REAL
https://h30434.www3.hp.com/
watch out for giggles, and ZINGS !
like where did find this , at Goodwill for a $1
or less?
infact go there find good PC for $20 and end this PDA thing.
surely you are not spending cash on it for a new battery right?
Jul 04, 2017 | Compaq iPAQ H3150 Pocket PC
Lights don't work
Don't know if I can solve it, but it is a Home Depot private lable. Try googling it and see if you can get some info. I suspect that you either hooked it up wrong, or it has damaged contacts.
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
HP ipaq 6315 No power
Hello i'd be happy to help :-). Since you said that you bought a new battery and it still didn't work. I am guessing that you might have charged you Ipaq by pulling it into a regular wall outlet . This is bad because that outlet could send to much electricity into the Ipaq and can kill it. That might be the problem why your Ipaq is not working... I would recommend for you to call HP and see if you can return your Ipaq to them and see if they can send you a new one.
Jun 18, 2008 | HP iPAQ H2210 Pocket PC
HP Ipaq 2410 screen alignment
relic, what good is this device?
why not ask HP , where if lucky , some one there can even remember that long ago.
its 14 years old. has zero value , seen in garage sales for $1
and no buyers.
why you? sorry but what good is it?> there is no service now.
my advice? is to dump this and buy a used real cell phone for $5
and work on that, work on something with a future and not this device IPAQ anything.
now here is real HP , this is not spam nor jackers or the like,
its the REAL DEAL, the maker of you DEVICE.
HP
Nov 26, 2017 | HP iPAQ HX2490 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
My ipaq 5450 is not charging
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Oct 20, 2007 | HP iPAQ H5450 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H5450 Pocket PC Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
