Question about Motorola Mobility RAZR V3
My screen okay, so today i was in the middle of a text and my screen just went black and i didn't drop it or anything it just went completly blank so i took the battery out of it and then put it back in and turned it on but the screen is still blank but everything else works i can still call but i can't see anything on the screen. what should i do?
  • Anonymous Jan 08, 2008
    After I ended a call my screen turned a green-yellow color and went blank. I have removed the battery and replaced it but I still have the same problem. I have also turned it on and off several times.
I am having the same problem with my phone, but it will stay black for long periods of time. i wish i had never bought it.
Posted on Jan 09, 2008
SOURCE:
I was texting on my phone when my phone screen went completely black. i thought i was maybe dead or i powered it off but i didnt.
Have you tried force shutting down your iPhone? To do this, hold down the Power Button and the Home Button at the same time for 5-10 secs, then power on your iPhone again, check if it works. Or try to reset your iPhone using iTunes (Backup your data first). If not, maybe the display of your phone is malfunctioning, send it to the nearest Apple Service Center for repair.
Mar 10, 2015 | Apple iPhone Smartphone
KYOCERA HYDRO SCREEN WENT BLACK
Look on youtube how to replace the LCD, looks like the light went out... the connector might just be loose..
Apr 19, 2014 | Kyocera Hydro Edge No-Contract Black...
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
Screen is blank
ya seems this is a problem of display connector u can fix it by fitting the display connector by opening the cell if it doesn't work then also then replace ur display
Mar 10, 2010 | Nokia N96 Cell Phone
Motorola Hint screen went black, but everything else works...?
i think the flex cable went loose. Just press the lower left corner when switching it on. it will help. has helped me
Feb 22, 2010 | Motorola Mobility Hint QA30 Cell Phone
LG Envy inside screen no longer works, did not drop or get wet, was using it fine then all of a sudden I opened it to text only to find a black screen, buttons still light up, but no display!
there is a small very delicate ribbon cable that connects the screen to the circuit board that has probally broken. it is a common problem on phones that flip like yours does.
Jun 01, 2009 | LG enV VX9900 Cellular Phone
Blank screen
Mine did this too. Once you dropped it, The screen went blank because it's the first time you've done it. Just leave it off for a few hours, And it SHOULD go back to normal... If It doesn't contact T-mobile. :)
Apr 16, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
LCD BLANK
Laptop Screen Dim, Blank Or Black - Notebook LCD Display Monitor ...
Click on the above link/ Follow instructions.....Good Luck.
Please dont for get to Vote.Thank You.
Dec 15, 2007 | IBM ThinkPad T30 2366 Notebook
Motorola Mobility RAZR V3 Logo
245 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
