Question about Arris SURFboard SBG900 (49402201900) Modem
Error message during installation of SBG 900
I am trying to connect a laptop to the modem via ethernet directly to cable outlet. When the install program verifies all connections it says it must change network settings to use a dynamic IP address (DHCP). When the 'next' button is pressed, an error appears: Director Player Error String Expected Script Error. Continue? At this point it will not let me continue. I have no idea if it a computer error. I am trying to connect a Dell Latitude D800. Any assistance will be much appreciated, thanks.
  • 1 more comment
  • joseph9 Sep 02, 2008
    I am having the same problem. what is the solution?
  • dauntlessras Dec 29, 2008
    im sorry that solution made no sense to me... please check if your modem..... what modem is walking?, and change the cofig where to static ip.
    been looking for awhile and being one with basic computer knowledge not very helpfull, and rather confusing answer
    um answer made no sense please make a more straight forward answer as this just confused me more
    Problem Solver:
  • 7 Answers
Please check if your modem and change the config to static IP.
Regards
Posted on Jan 06, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
How to Install DLink DIR-615 with only 1 port on my laptop?
Connect the modem to the router via the ethernet cable. Connect the laptop to the router by means of another ethernet cable in one of the 4 spare sockets. Switch everything off. Turn everything back on one at a time, modem first, then router, then laptop. Allow each unit to fully power up before switching the next one on. Put the installation CD in the laptop and try again. If you are using the laptop wirelessly, make sure the wireless function is switched on!
Apr 12, 2009 | Computers & Internet
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
I am trying to install a cable modem with usb and ethernet connections on a windows xp computer.
Well there are 2 ways
via Ethernet
1.) connect the ethernet from the modem to the ethernet of the computer via the cable provided and thats should basically setup and give you an ip automatically
Via Usb
2.) install the drivers that came on a cd with the model
2.) follow the onscreen instructions and connect the modem via the usb cable when it tells you to
3.) when setup is complete it will create a connect icon for you, just run it to connect
Jul 14, 2008 | Computers & Internet
Toshiba satellite L200
Installing the Yahoo Messenger 8.1 needs an Internet connection. It could be that your laptop is disconnecting to the Internet while you're installing Yahoo Messenger 8.1 that's why it will not finish the installation process.
Make sure that your laptop has a stable Internet connection before installing the YM 8.1. If you have a modem or a router, it would be better to connect it directly to the modem or to the router with an ethernet cable rather than using the wireless connection.
May 07, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
Arris SURFboard SBG900 (49402201900) Modem Logo
455 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
