Question about Westinghouse Turbo Swirl 78145 Ceiling Fan
Removing the globe for put bulb in
We are building a house... the electrician my builder hired installed three of these cute fans, but told me the reason the lights don't work is because I didn't provide the correct bulbs --- well, I can't even figure out how to remove the globe - this design is horrible. On one, I took the screws out, couldn't figure out how to get inside the globe so now the light portion is dangling from the fan and I am about ready to just give up on it and buy a different fan, just to save myself the added aggravation. Any ideas?
  • Anonymous Feb 08, 2009
    I'm glad I'm not the only one with this delemma, and I've had a terrible time finding the answer!
  • Anonymous Mar 10, 2009
    Do all models of Westinghouse Turbo Swirl have 3 speeds?
    Problem Solver:
  • 6 Answers
You simply twist and tug the globe (firmly but easily) and find that it is held on by three "tension clips" that hold the thing in place.
If you are nervous, have someone else get on the other side of the ladder and hold the fan steady while you twist/tug the globe with two hands.
I did it by myself but I would have liked another pair of hands holding the fan steady while I gently but firmly tugged at the globe.
It's a bit of a drill to get the thing back on. You have to get all three clips inside the globe and sort of slap the thing back into place. It won't come off easily; so be prepared to do some firm yet gentle and steady tugging.
Posted on Aug 30, 2009
I found on mine that the bulb is held in with 3 tenshion clips. You just have to pull the globe down slowly to gain access to the light bulb.
Posted on Feb 09, 2009
  • 625 Answers
The metal bell part holds all the wiring in place. the globe fastens by two thumb screws 120 degrees apart with an internal hook at the other 120 degree point. unscrew the screws and tilt out the globe. replacement bulbs should be no more than 60 watts.
Posted on Sep 07, 2007
SOURCE:
Harbor Breeze Portes ceiling fan. How do I replace the lamp?
Check a home-depot store, if you see a similar fan, ask for the sales person to show you.
Jun 26, 2015 | Dryers
How to change the bulbs I turn and turn the globe and lower assembly but the glass doesn't release! The shaft rises up slightly but then clicks back down Any suggestions?
Hampton Bay assembly information is tough to come by on the internet - except for sales info. As an electrician, I have hung more fans than I can remember, and have never found any that were not secured by either (1) three or more thumb screws, (2) a threaded portion of the glass globe or (3) a "bayonnette" (quick twist) type mount that required little more than an inch or so of twist to remove.
The globe should be removed by either loosening / removing three or more thumb screws that are designed to engage the recess between the globe itself and a lip around the opening; unscrewing the glass globe light a light bulb ; OR by twisting the globe about an inch or so in one direction or the other (like many automotive-type lamps). I suspect the type you have is the latter. From your account of what is happening, it suggests to me that the entire fan / light fixture is twisting on the fan support on the electrical ceiling box when you are trying to twist the globe. The globe and rest of the fixture are moving as one instead of independantly of each other.
If yours is the type that must be twisted from the base, you'll need to prevent the rest of the fixture from twisting at the same time while attempting to remove the globe. This will probably require a second person to help - given that it seems to have become wedged in place, and trying to grip it and balance the globe might be to much to do by yourself. If yours is held in place by thumb screws, no amount of twisting will allow it to be removed.
There should be no "secret" way of accessing the light bulbs, something has happened that is preventing the easy removal of the globe - whether it is corrosion, dirt or some other debris. Make sure you clean it up completely before reassembly.
I hope this helps! Good luck!
Nov 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Should a twoway room fixture actually be a three way ?!?!
The leviton 5603 switch described in the header is a three way wall switch.
I think what you are asking about is what electricians refer to as a "three way switch"
This is basically one outlet or device connected to two wall switches. 1) switch, 2) outlet or light fixture, and 3) another wall switch, three components, thus a three way switch. Installing or converting a fixture or outlet from standard to three way is something i would recommend contracting out to a licensed electrician. Unless you are really comfortable with electrical work.
It is a possibility that your wall outlets are already set up to be a three way switch. A lot of houses have this feature especially at the top and bottom of a stairway, depending on when your house was built. If it is not already configured it could mean stringing new wire behind the drywall which most often means tearing some of the drywall out so that it can be stapled to the studs and meet required building codes.
If, before the changes were made, you were able to turn on the light from either of the wall switches then you will only need to connect the wiring correctly at each of the components.
If you google 3-way switch you will find a ton of great info and wiring diagrams that will help you see exactly what goes into making them work, since they can be wired more than one way. It could help you decide whether or not it is a job you want to tackle on your own or if you want to hire a contractor.
Let me know if I didn't explain something clearly.
Mar 01, 2010 | Leviton 5603-wh 3 Way Decora Switch
Light bulb replacement in ceiling fan. Hampton Bay with a solid globe (no hole in middle) - how to remove globe?
Look for three or four small thumbscrews around the metal rim that holds the globe. Unscrew each several turns while holding the globe with your other hand underneath to keep it from dropping out. You should not have to remove the screws completely. Just loosen them all enough to remove the globe. If there are no screws then the globe may twist into the rim light a light bulb. Hold the fan housing steady and turn the globe counter-clockwise to unscrew it. If it turns but does not unscrew then there are probably screws holding it as first described. They may be flush with the rim and you may need a small screwdriver or Allen wrench to unscrew them.
Oct 16, 2009 | Dryers
Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Jan 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Install a Thermador UCV36 cook'n'vent
Hi schmidt_rich,
I'm Harvey the Master Plumber.
Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
777 people viewed this question
Top Westinghouse Dryers Experts
Paul Bade
john h
Sr. Pelo
Sr. Pelo
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
