Question about HP PhotoSmart 7760 InkJet Printer
Print cradel CRASHES!! into the right side of my printer
This started randomly and now is a permanent problem. When my printer is called onto print, (either via front panel or computer) I whirrs and buzzes, then.... SLAM, it throws the cartidge cradle into the right side of the printer. Then gives the obvious message, your print cradel is jammed, clear and hit OK. Hit OK and then SLAMM!! Yikes, it scaring the heck out of my cat, and its not printing. Any ideas? I followed HP suggestion to reset the clutch, but no luck.
  • 59 Answers
There is a thin, clear plastic strip that guides the carriage & stops it from slamming like that. it is broken sadly. try getting one from ebay and switching it out. We got ours for like $13 shipped
Posted on Oct 02, 2007
SOURCE:
Printer prints random characters
Hi Erica,Try to shut it off, but if you can't, unplug it. Then try canceling it and plug it back in.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 06, 2014 | Brother Office Equipment & Supplies
Mine keeps initializing by itself randomly..then freezes up.
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
May 20, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have a Kyocera Mita KM-4230 and I'm trying to print a #10 envelope and its asking me to use the MP tray. But it's not accepting the envelope, what do I do?
but the envelopes in the tray on the right side of the machine... open all other trays.... and attempt to print... it will ask for you to select the tray... in which case you select the mp tray... and print... now for a more permanent solution... call kyocera support and they will walk you through the proper procedures...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
check the sensor , either there is somthing stucking on the sensor you cannot see it, either the sensor it self becomes bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 17, 2009 | Office Equipment & Supplies
Printer crashes
Hi Ann,
Check the ribbon cable that comes out of the back of the print carriage for damage / disconnection. They don't normally wear loose, but it is possible.Failing that, the print engine could have failed, which would deliver duff data to the heads, thus printing rubbish onto the page.
Mar 05, 2009 | HP DeskJet 670c InkJet Printer
I have an MP730
This may noy have a solution. sorry. if the cart actually moves and then it crashes onto one side, your problem could be the printing head. this is much more expensive than a new printer. you may wanna try to change cartridges (both) and see if it responds. sorry to say :S
Jan 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
HP psc 1110 problems
had a similar problem resolved: if you are on Win XP select <start> <printer & fax> then right click on <hp psc 1110> and then on <extended>; select <send print jobs directly to printer> rather than thru spooler; setting should be permanent but tends to flip once in a while.
Nov 13, 2007 | HP PSC 1110 All-In-One Thermal Printer
7550 Cradle CRASHES!! into side of printer
I had the same problem with my 7550. I followed this shortcut and so far so good. Be real careful with the strip cleaning and don't use anything but a damp cloth. No solvents.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpd50646
Oct 29, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
111 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
