Question about Vivitar V3800N Zoom 35mm SLR Camera
Turn it on
I just got this camera from a consignment shop, it didn't have a manual so I don't even know how to turn it on. Or anything else for that matter. I hope you can help, if you could just explain how to turn it on I would really appreciate it. Thanks
  • 3 Answers
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Posted on Sep 03, 2007
SOURCE:
Honda cr- v climate control not working
Don't think your mechanic looked up anything to do with
your model vehicle or cares to
Without diagnostic manuals you can not work on it yourself
I guess a dealer would know more than some repair shops,
most shops would be my first choice, but not the one you went to
Clearing anything is not a fix for anything
If your mechanic told you all sorts of things, then why didn't they
resolve them,they don't know,that's why,most likely have no data base to work on much of anything
If there was low pressure before you bought it, why is it okey now,
but not work properly,sounds like nonsense to me.
Sep 18, 2012 | 2007 Honda CR-V
I had a mechanic come out and work on my Laredo about 8 months ago; it was leaking fluid from the rear main seal. He didn't fix the leak and since then the gear indicator doesn't match up, and I...
I don't know how you thought he could fix that leak when the trans has to come out? Take it to a transmission shop and stop guessing, and replacing perfectly good parts. Have the trans shop replace the rear seal while the trans is out.
Sep 12, 2011 | Jeep Grand Cherokee Cars & Trucks
I am currently on vacation and I was taking pictures with my Olympus FE-230 and when I now turn it on it tells me that I need to format my card but in doing this it will delete all my pictures. I cannot...
I know how it can be frustrating not to loose your files..............my recommendation may be a bit hard but it is tried and tested.
  1. Have your camera format it that is if you believe that the card is not faulty.
  2. Use the card any how you want!
  3. Get a recovery software which will recover all files that was deleted no matter what you did to the card and use it to recover all your old pictures . (i can provide this software for free if you so wish)
good luck and let me know the outcome
Aug 04, 2011 | Olympus FE-230 Digital Camera
Turn it on,don't know if it even works.
Hi There
I assume you found this camera and don't have any information about it.
Here is a link to download the manual.
http://www.retrevo.com/support/Vivitar-3710-Digital-Cameras-manual/id/200ag804/t/2/
If you don't have a cord to connect it to your computer, you can purchase one:
http://www.amazon.com/Vivitar-ViviCam-3710-USB-Cable/dp/B003HMVENA
Hope this helps!
Jul 26, 2011 | Vivitar ViviCam 3710 Digital Camera
I just got a Mamiya rb67 on ebay and I cannot get the cocking release lever to move or the shutter for that matter. I didn't want to force anything. I have looked at the manuals on the web, but cannot...
Have you tried it without the back attached, or without a dark slide in the back? Many cameras have an interlock preventing the shutter from firing while the slide is in. If that doesn't work, remove the lense and try it all over again - many times on these model's the problem lies in the lense, not in the body.
If neither works, consult a tech. But, expect more in repairs than you probably paid for the camera since these things are going for well under $300 these days.
Jul 26, 2011 | Mamiya RB67 Pro SD Medium Format Camera
Talked to two experts yesterday - the first one talked to me about a camera that isn't even the one I have, he spoke of Canon instead of Contax, and the second one's advice didn't do the...
First, try removing the batteries and then reinstalling them. If the problem persists, you may wish to try a new battery. If this doesn't solve the problem, you will need to send this camera in for repairs. Parts for this camera are hard to find so you will want to have an experienced Contax repair company to repair your camera, like TOCAD.
TOCAD is the only repair company for Contax in the United States that I know of. Here is there site: http://www.tocad.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2011 | Contax NX 35mm SLR Camera
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
I have a Sanyo digital camera, model: VPC-X1250; it now takes blurry pictures where you can't tell what the subject is even when i am inches away from the person's face. it also turns on, makes a...
hi According to your information, somehow your camera has lens unit defective. Your local repair shop would charge around $ 35 to 75 depend on what really want to charge. Thanks and best regard!
May 24, 2011 | Sanyo VPC-X1250 Digital Camera
Vivitar V3800N Zoom 35mm SLR Camera Logo
290 people viewed this question
Top Vivitar Photography Experts
Photo Beagle
Level 1 Expert
Ekse
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
