Question about HP Media Center m7250n (ED842AA) PC Desktop
Burn error As I stated in a earlier question I can burn a dvd successfully , but every time I attempt to burn a cd (data,audio) it always errors out at the end of the burn process. I'm posting the log file in hopes that somebody can make something out of it. I have tried to update the driver from HP but there was not one. It is an HP dvd writer 640c. Thanks NT-SPTI used Nero Version: 7.0.0.0 Recorder: Version: QS12 - HA 1 TA 0 - 7.0.0.0 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: Version: HD07 - HA 1 TA 1 - 7.0.0.0 Adapter driver: HA 1 === Scsi-Device-Map === CdRomPeripheral : HP DVD Writer 640c atapi Port 0 ID 0 DMA: On CdRomPeripheral : IDE-DVD DROM6216 atapi Port 0 ID 1 DMA: On DiskPeripheral : WDC WD2500JD-22HBC0 atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === HP DVD Writer 640c E: CDRom0 IDE-DVD DROM6216 F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1014MB (1038764kB) Free physical memory: 366MB (375400kB) Memory in use : 63 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 2.9.2007 CD-ROM (ISO) 3:02:22 PM #1 Text 0 File Isodoc.cpp, Line 6410 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 3:02:23 PM #2 Text 0 File Burncd.cpp, Line 3007 HP DVD Writer 640c Buffer underrun protection activated 3:02:23 PM #3 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 81920KB of Memory 3:02:23 PM #4 Text 0 File Reader.cpp, Line 124 Reader running 3:02:23 PM #5 Text 0 File Writer.cpp, Line 113 Writer E: HP DVD Writer 640c running 3:02:23 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3304 First writeable address = 0 (0x00000000) 3:02:23 PM #7 Text 0 File Burncd.cpp, Line 3301 Turn on Track-At-Once, using CD-R/RW media 3:02:23 PM #8 Text 0 File DlgWaitCD.cpp, Line 277 Last possible write address on media: 359845 ( 79:59.70) Last address to be written: 357704 ( 79:31.29) 3:02:23 PM #9 Text 0 File DlgWaitCD.cpp, Line 289 Write in overburning mode: NO (enabled: CD) 3:02:23 PM #10 Text 0 File DlgWaitCD.cpp, Line 2568 Recorder: HP DVD Writer 640c 3:02:23 PM #11 Text 0 File DlgWaitCD.cpp, Line 456 >>> Protocol of DlgWaitCD activities: <<< ========================================= 3:02:23 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 846 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 357705 (357705) = #357705/79:29.30 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 357703 blocks [E: HP DVD Writer 640c] -------------------------------------------------------------- 3:02:23 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1058 Prepare recorder [E: HP DVD Writer 640c] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 732887040, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 357705 | lead-out | 1 | 0x41 | 0x00 3:02:23 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1126 Removed 2 run-out blocks from end of track 1. Length: 357705 -> 357703. 3:02:23 PM #15 Text 0 File SCSIPassThrough.cpp, Line 34 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 3:02:23 PM #16 Phase 24 File dlgbrnst.cpp, Line 1724 Caching of files started 3:02:23 PM #17 Text 0 File Burncd.cpp, Line 4129 Cache writing successful. 3:02:23 PM #18 Phase 25 File dlgbrnst.cpp, Line 1724 Caching of files completed 3:02:23 PM #19 Phase 36 File dlgbrnst.cpp, Line 1724 Burn process started at 40x (6,000 KB/s) 3:02:23 PM #20 SPTI -1189 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x02 CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 30 02 Buffer x04e55200: Len x4000 3:02:24 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2669 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 3:02:24 PM #22 Text 0 File MMC.cpp, Line 21541 Set BUFE: Buffer underrun protection -> ON 3:05:01 PM #23 SPTI -1135 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 04 07 40 00 00 20 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 12 00 00 00 00 0C Buffer x0a290000: Len x10000 0x7B 1B 6A 8F 20 72 AD A3 D9 E9 2D 99 7F 6B 12 18 0xBD F5 86 41 25 77 71 20 7C 5D E5 56 CB FD 1F FF 0xB6 F2 FD 6E 42 63 96 DB 69 F6 82 38 4A 16 6C D9 3:05:01 PM #24 CDR -1135 File Writer.cpp, Line 302 Write error E: HP DVD Writer 640c 3:05:01 PM #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 3:05:01 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 3:05:02 PM #27 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state E: HP DVD Writer 640c 3:05:02 PM #28 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 3:05:02 PM #29 Text 0 File MMC.cpp, Line 16273 start Close Session 3:05:06 PM #30 SPTI -1176 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x72 Sense Qual: 0x01 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 12 00 00 00 00 72 01 3:05:06 PM #31 CDR -1176 File WriterStatus.cpp, Line 249 Session fixation error E: HP DVD Writer 640c 3:05:06 PM #32 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 3:05:06 PM #33 Text 0 File WriterStatus.cpp, Line 258 falling back to disc fixation 3:05:06 PM #34 Text 0 File MMC.cpp, Line 16273 start Close Session 3:05:06 PM #35 SPTI -1122 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1122) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x57 Sense Qual: 0x00 CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 57 3:05:06 PM #36 CDR -1122 File WriterStatus.cpp, Line 249 Unable to recover TOC E: HP DVD Writer 640c 3:05:06 PM #37 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 3:05:06 PM #38 Phase 38 File dlgbrnst.cpp, Line 1724 Burn process failed at 40x (6,000 KB/s) Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 8/24/2006 11:47:00 PM File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 3/7/2007 7:51:00 PM (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
(KEY_MEDIUM_ERROR Check your disks
Posted on Apr 30, 2008
  • HP Master
  • 12,061 Answers
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Posted on Sep 03, 2007
SOURCE:
I have always been using Nero burn software with my LG GSA-2166D DVD RW. Now I bought Nero Multimedia Suite 10. No any writing process has been successful. I have since yesterday spoiled 10 DVD's....
speed of source data is too slow = the hard disk cannot deliver the data fast enough and the burning process stops; this is a sign of a severely fragmented file system and very charged background processes: defragment your hard disk, stop using other programs when burning a disk and use 8X as a recording speed.
 Track Following Error = the laser head in the burner is no longer capable of following the track it has itself burned - the lens is dirty, clean it.
Jun 12, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
Error message when attempting to create a DVD
Try to burn your programs using a different burning software like nero or etc.
Nov 08, 2009 | Microsoft Windows XP Media Center Edition...
I have been attempting to burn a cd from my itunes library, it keeps giving me an error 2630. Yes I am using a new blank cd.
What type of CD media does your burner support? CD+R CD-R, CD-RW.
A few suggestions:
CD-RW or re-writables do not support audio burning to CD format.
Are songs being burned as a data disc(unplayable files) or CD audio?
Have you exceeded the 700 to 800 MB range of data that a CD can hold?
Try dropping a couple of songs off the list and see what happens.
Try rebooting the computer and try burning again.
Down load a free version of Nero software and try to burn the CD from there.
Oct 13, 2009 | HP HewlettPackard Pavilion ZE5400 series:...
I have a hp pavillion dv9000 dual core 64 bit windows vista home prem. i am gettting an error code oxebo20b88 when i am trying to burn a data disc.
Are you burning a DVD.is it DVD-R (or rw) If it is - Please try a DVD+R(or rw)
some people have reported problems with DVD - discs and + discs worked perfectly.
Aug 01, 2009 | Office Equipment & Supplies
Cannot burn a DVD
try freeware program burnatonce, it's smaller and has same functionality, maybe not too much of graphics, but gives you all the details, even about the cd-r/dvd-r u use, it is worth trying.
Jul 23, 2009 | Microsoft Windows XP Professional With...
MP3 to CD burning crashes Windows Media Player
i have no converter about it but there are others u maybe like
i prefer eztoosoft for its clear converting image and fast speed. The most important thing is that it is easy to use, especially for beginners. If you are interested, you can see its sites and make further comparison. I usually visit
http://www.eztoosoft.com/eztoo-dvd-ripper-for-mac.html
you can have a try.
Guidance
http://www.eztoosoft.com/eztoo-dvd-ripper-for-mac.html#guide
Apr 25, 2009 | Computers & Internet
I cant burn or play dvd
try to burn at a slower speed, turn off the screen saver and virus scanner? if these try to run while a burn is going it can cause an error, try to defrag the hardrive if needed before the burn, try another brand of media , check for software updates on the burning software
Nov 26, 2008 | Optorite (dd0405) DVD±RW Burner
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
Factory default disc on acer 4520G
If you have Nero of Power ISO installed you can right click the .iso file and there should be a command in the shortcut menu that states "burn with Nero" or burn iso with Power ISO, etc. this should apply to other disc burning software you have installed.
As you may know, .iso files are a compressed disc image file that contains the data layout for a complete CD or DVD. Most of the time, burning an iso image from first opening your disc burning software is more difficult but can be done by hunting through your software's menu commands.
Hope this has fixed ya!
Worldvet
May 16, 2008 | Computers & Internet
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Open Questions:
Epson Wireless Printer CUSTOMER service pHoNe:~{-1{855'26O+0O64-}nUmBeR USAdfcas Epson Wireless Printer CUSTOMER service Number +1{{855'22l-4867}Wireless Repair service center to resolve all Epson Printer tEcH SupPoRt pHoNe nUmBeR products. Epson Printer ROUTER is an American multinational company which was founded by Michael Epson Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Epson Printer ROUTER support number, and selling of computer-related services and products. Epson Printer ROUTER Tech Support Phone Number Recently, Epson Printer ROUTER has been named the number Epson Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Epson Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Epson Printer ROUTER Service Tag or a Epson Printer ROUTER Get Epson Printer ROUTER Technical Support Phone Number and Customer Services. Epson Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 17, 2019 | Epson Computers & Internet
See all HP Media Center m7250n (ED842AA) PC Desktop Questions
HP Media Center m7250n (ED842AA) PC Desktop Logo
953 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
