Question about Uniden GMR638-2CK (22 Channels) 2-Way Radio
Constant Rx Our radios have all steadily developed this problem but for no clear reason (Some have been dropped but this developed later. Whenever we turn them on they are constantly in receive mode. Showing Rx on the screen and with constant squelch (Really annoying!) Switching mon on and off doesn't help and there is no apparent internal damage. Any ideas? We have about 15 of the suckers in need of a fix and of course all are out of warranty........
Re: Constant Rx
I have a UH036SX so not sure if its exactly the same. If you open up the unit, there is a large black potentiometer near the base of the antennae. I found if I wound this counterclockwise by approximately quarter of a turn with a small flat blade screwdriver it reduced the squelch level to a better level. I suggest wind it down until the static is gone, then increase slightly to give the best level.
Posted on May 25, 2013
    Brigadier General:
  • 6,966 Answers
Re: Constant Rx
Hi, It would initially seem that your auto squelch is malfunctioning. With the squelch apparently way down, the RX indicator would automatically appear as if you are receiving something (even if it were just noise). Assuming no other fault except the auto squelch, a possible workaround is to use any of the 38 CTCSS codes both in receive and transmit. With the CTSS activated (TX/RX), even with squelch all the way down or auto off/defective, you will not hear anything except a radio transmission with the correct CTSS code. Again, this will only work of course with just the auto squelch muting problem. Any other problem/fault and this method may not work. Hope this be of some help/idea. Post back how things turn out or should you need further information. Good luck and kind regards.
Posted on Sep 03, 2007
0 characters
3 Points
How do i repair a Kenwood ts450s fron tx and rx on both sidebands at the same time.Other modes work fine?
this is typical of Kenwood, reseat EVERY connector in the radio and try again, if it still does this, it more than likely has developed some bad solder joints
Sep 20, 2014 | Two-Way Radios
Uniden uho43sx 2
rx means its in receive mode, what happens when you push the PTT (push to talk ) ?
May 24, 2014 | Two-Way Radios
Stuck on rx mode
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
Uniden uh064sx-2a constant rx
Press PTT and see its break receiving. Also change the Rx frequency or change the channel which not receiving, adjust the squelch level.
Dec 28, 2013 | Uniden GMR638-2CK (22 Channels) 2-Way...
My uniden walkie talkie has the RX button stuck on the screen i can talk to the other person but it always makes a screeching noise
Hi Laura,
When you see the Rx sign on the screen, it indicates that someone else is transmitting (Tx) on the channel, this is also caused by "BOOF HEADS" who like doing nothing more than dropping carriers by holding down their PTT button during a conversation, something that happens a lot on CB and without a doubt on FRS radios.
There is no problem in your radio, it's Just someone else probably dropping a carrier as per above.
Not much can be done about this problem, No License, No Joy.
The fact you can hear the other person over the screach indicates to me that I am right, and your radio is fine.
I hope this clears up your query.
Warm Regards,
Jan 13, 2013 | Uniden GMR-1088 2-way Radio Walkie Talkie...
Midland GXT 550 two way radio has a constant RX read out on display as though it is constantly receiving.
my 550 got wet wos leftout in the rain now after three mounths it shows a low battery
Dec 12, 2009 | Midland Two Way Radio
Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Jul 23, 2009 | Cobra Two-Way Radios
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Uniden GMR638-2CK (22 Channels) 2-Way Radio Logo
1,212 people viewed this question
Top Uniden Two-Way Radios Experts
Michael Thomas
Michael Thomas
Are you an Uniden Two-Way Radio Expert? Answer questions, earn points and help others
