Question about Magic Chef CER3725AA Electric Kitchen Range
What is this F-! mean
Just got done usin my oven now have no time just an f-1 wont go away never had a prob with stove or oven what do i do to get my time back hope nuttin is wrong with my stove
I know the Magic Chef frustration all too well. I had an oven burner actualy shatter before this annoying F1 event. I found the nearly impossible element online at repairclinic.com wich is a parts seller. I checked the site and found Magic Chef codes there as well at http://www.repairclinic.com/0078.asp#MagicChef . I am posting the link because it lists all other codes too. F1 failure code lists two conditions. 1) watchdog on board 2) touch membrane defective. Under check/repair , it lists ," To determine wich component is at fault, disconect ribbon strip. If no fault code , replace membrane, otherwise replace board. Seeing that I have no problems with any function and it is an old stove, I am going to follow the sollution posted by a gent here and remove the beeper wire. I will not suggest anyone tries it , but thats what I am going to do. You have to watch what you say nowdays. We know all too well some idiot would try it and accidently stick his tounge on the main power line and try sueing..lol
Posted on Sep 30, 2008
Tripping the breaker(stove) on house elec. panel seemed to work.
thanks.
Posted on Feb 20, 2008
  • 22 Answers
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Posted on Dec 04, 2007
SOURCE:
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
Stove works oven wont turn on. now is reading fault code (SA6). what does that mean? and how do I fix the proble
If sab Push and hold clock button in for a few seconds.When it clears, the oven should work fine. God-Bless! Just let me know if that works. It is in sabbath mode. Research said it is sab not sa6,
Dec 28, 2015 | Maytag Range Oven Part - Oven Temperature...
The burners on my Maytag electric stove work intermittently. Advanced cooking system Super capacity model.
If intermittenly you mean they quit glowing at times is how mine work also and wife does not say they don't cook alright but they do turn off and on as heat requirement changes
Jan 11, 2015 | Maytag Gemini 30" Self-Cleaning...
Gas stove cooktop electric pilot light keeps clicking and wont shut offf
sounds like you have it handled...
Easy?
just a phone call away... this time , when he fixes it , watch what he does... so you can fix it next time.
Mar 24, 2013 | Tappan Kitchen Ranges
Oven wontr come on, but broiler does//
you have a bad ignitor part number 74007498 and it's around 65 dollars.pull out the racks and remove the floor of the stove and you'll see the ignitor screwed to the burner tube,wet the screws with a wet paper towel,they will come out easier or if it makes it any easier remove the tube and then remove the ignitor.first start the stove if the ignitor glows but doesn't ignite the flame in 40 seconds or less it's bad,if it doesn't glow at all check it for continuity but it sounds like the ignitor is bad,if the new ignitor comes with wire nuts,cut the wires close to the body of the old ignitor,trim some of the wires back on the new ignitor and wire nut them together with the ceramic wire nuts,on some you can get the screws out of the ignitor,cut the wires close to the body,mount the new ignitor,trim back the wires on the new ignitor and wire nut them together and you're done,it doesn't matter how long the wires are just as long as the wire nuts are under the floor and away from the tube.it might help to remove the bottom draw to get at the wires,hope this helps and good luck.
Dec 11, 2011 | Maytag MGS5870 Gas Kitchen Range
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Magic Chef CER3725AA Electric Kitchen Range Logo
441 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
