Question about Philips (33-01-031) Headphones
Batteries for Philips wireless headphones
It says only use Philips rechargeable batteries SBC HB550S
Can you please tell me where the batteries can be obtained
as they are not available from Philips and other Ni-MH batteries will not charge in the headphone base unit
  • 11 more comments
  • Anonymous Apr 18, 2009
    I have the same problem
  • boris86868
    boris86868 Dec 27, 2012
    genius
  • Pauline Barry
    Pauline Barry Jan 11, 2013
    THANK YOU FOR THIS SIMPLE SOLUTION
  • Carole Warner
    Carole Warner Feb 06, 2013
    Wonderful! The most useful info I've found on the Net. A thousand thanks!
  • Andrei Jugantsov May 05, 2013
    YES! It works! simple solution! Thank you very much! I was already planning to but new headsets, so you saved me around 70 EUR!
  • Paul Baldwin Oct 04, 2013
    BRILLIANT!!!
  • Herbert
    Herbert Dec 10, 2013
    I have the same problem. They don't tell you when you buy it. i think i will throw it away and never buy a phi;;ips again
  • Arne de Vos
    Arne de Vos Jan 31, 2014
    solutions are working!
  • Jillian Stella
    Jillian Stella Feb 01, 2014
    Thank you for your help - a great site for problem solving. Saved me looking around for something I most probably wouldn't find. Cut off the plastic as suggested on my 850mAh and they work fine.....Many thanks once again.
  • ian jonson
    ian jonson Jun 08, 2014
    thanks! removing the plastic did it!! i will never buy from philips again for wasting my time and making my life harder to line their own pockets a centremeter to the lightyear
  • DERICK SWART
    DERICK SWART Apr 03, 2018
    THANKS FOR THIS TIP!! I HAVE THE SAME PROBLEM WITH MY INFRA-RED WIRELESS HEADPHONES. I HAVE 4 SETS OF THEM THAT I USE FROM TIME-TO-TIME AND I WAS LOOKING FOR THE REPLACEMENT PHILIPS SHORT-SLEEVE BATTERIES THAT WAS LOST BY THE PREVIOUS OWNER THAT HAD THEM. I AM GOING TO DO THE SAME BY REMOVING THE "-"END PART OF THE LABEL!! THANK YOU GUYS. "DONDERDESWART" SOUTH AFRICA.
  • Mir Ali Khan
    Mir Ali Khan Mar 15, 2019
    Blimey, it worked for me too for the $ Store batteries!!!!!
  • Vincent Lau
    Vincent Lau May 23, 2019
    Any suggestions to replace the original battery model HB550S?I I tried to find the place to order it but it seems this model was no longer to supply. Can I use the SANYO NiMH rechargeable battery to replace it.
Actually, look at the Philips SBC HB550S battery, the black label on battery isn't going to the end of the battery's "-" side, there's few millimetres of solid metal. Look at other, ordinary rechargeable battery, for ex duracell's. This other battery has label all over battery (from "+" to "-"). So only thing you have to do to make any batteries work with you have to cut and remove this label from battery you want to use from the "-" side of the battery, about 1-2 cm, like philips one has. It's because these headphones have this extra clip in battery sockets, philips wants us, customers, to buy those extra-expensive batteries. That's as simple as it is! Hope it helps you, it definitely helped me.
Posted on May 04, 2009
  • 24 more comments
  • patmikemurph Sep 14, 2010
    youre a very canny man murdo thanks a million !!!!
  • sulla123456 Jan 05, 2011
    I tried cutting off the bottom part of some duracell AAA batteries and installed. It seemed to work, but even when switched off, after about ten minutes it heated up so much some of the plastic started to melt....any suggestions?
  • Patrick Apr 06, 2012
    YES ! Ignore the negative base spring-contact, it doesn't! The contacts are the ones touching the sides near the base! This had been driving me crazy! What a very crafty trick on Philips' part!
  • eminipek
    eminipek Aug 06, 2012
    Thanks for the tip! It works great.
  • paul williams Aug 13, 2012
    WORKS A TREAT, MANY THANKS
  • Nicholas Martin Jun 11, 2013
    Thanks SO much. It works and you've saved me some money!!!
  • Sandro Tomasi Sep 01, 2013
    Thank You !! the trick is simple but hard to find!! thank you and the internet
    BRILLIANT!!!
    Thanks a lot Murdho,great suggestion and it works perfectly with any rechargeable AAA compatible.Great small trick!
  • Herbert
    Thanks Murdho. It works perfect
  • Arne de Vos
    thanks, working now with Duracels
  • Jose Ignacio Palacio Gonzlez
    thanks for the explanation, has been very useful for me!!
  • Sam Sri Lanka
    Sam Sri Lanka May 31, 2014
    murdho, you are TRULY a GENIUS. What is your I.Q.??? I thought I was smart, till I came across this post of yours! Now I feel downright stupid! Anyways, thanks very, very much!!!
  • Graham
    Graham Jun 15, 2014
    Thanks for this tip. I have removed part of the label and the green light comes on on the charger. But no red light to show it is charging
  • Lea Oliver
    Lea Oliver Jun 27, 2014
    I, too, removed part of the label on a Duracel battery and hey presto it is charging in the docking station and is also showing the charging light. Thanks so much for the tip!
  • Lea Oliver
    Lea Oliver Jun 28, 2014
    Further to my last comment, the charging light came on but when I came to use the headphones, there was nothing there! Still not working so will have to try and find Philips batteries, Lea Oliver
  • Rocky Pete
    Rocky Pete Sep 18, 2014
    It worked for me. Thank's a lot!
  • Debs
    Debs Aug 17, 2017
    Hi, I tried the suggestion and made sure that the sticky residue from the gum was completely cleaned off. This can cause problems with connectivity and flattened the plastic around the area. To my surprise it has worked really well.
  • Turk
    Turk Nov 20, 2017
    Thank u so much murdo. You wrote this in 2009. You solved my problem 8 years later. I hope u r alive. Thanks so much... I m an electrical engineer but i cant explain how it works with this easy peeling.
  • Anonymous Dec 03, 2017
    Another +1, 8 years on! Specifically however (as Debs points out), make sure to FULLY remove any residue. After my first attempt they looked quite clean, but no joy... I spent an extra 10 mins to rub all the glue off, and hey presto, working perfectly!
  • Anonymous Jan 20, 2018
    Well it seems that the charging contacts are on the side in de battery compartment on the philips headset... normally they are on the ends...
  • Ninoh FOX
    Ninoh FOX Mar 08, 2018
    Thanks!! This works!!
  • Santiago Espin Perez
    Santiago Espin Perez Oct 29, 2018
    Works for me! Thank you very much
  • rohan dogra
    rohan dogra Mar 07, 2019
    Thank you so much it really work I was surprised......
  • Mir Ali Khan
In my point of view, philips used this metal on the bottom side to charge using the docking station as a safety feature ( beside selling purpose of course ), so it will prevent when someone use ordinary batt ( not even rechargeable one ) and put it in the docking accidentally.. and yes, i just peel my bottom side new 1000mAh and it works like magic.. so, dont blame on philips to try tobe cautious and getting rich at the same time.. :)
Posted on Mar 14, 2010
  • galanthus800 Nov 13, 2010
    This worked perfectly for my mum's headphones - we couldn't get philips rechargeable batteries anywhere and kept being told ordinary ones should work in the charging unit - which of course they don't. I followed your suggestion of peeling off the bottom 5mm of plastic from the flat end of the batteries and it has worked beautifully!! THANK YOU SO MUCH!
  • Mir Ali Khan
I have the same problem.. The little metallic bit at the end of the battery (-) is essential for being able to recharge the batteries using the Philips SBC HC8852 and I presume for other Philips headphone sets.
I have tried with batteries of 800mAh instead of the recommend 550mAh and I didn't work after removing the plastic of the batteries. But when I tried using 600mAh ones it worked fine.
Get your own choice batteries and remove the plastic and it will work
Good luck
I hope i could have found this forum before getting my 800mAh useless batteries...
Posted on Jan 16, 2010
  • 3 more comments
  • NicolaMoans Feb 17, 2011
    Thanks, Thanks, Thanks. Shame I turned to your site in desperation after buying another set of batteries.
    Both sets are happy and working fine.
  • davesmith100 Jun 21, 2011
    Thanks, was tearing my hair out as it seemed so illogical
  • WXOLF
    WXOLF Jun 09, 2017
    Thanks same issue
  • Debs
    Debs Aug 17, 2017
    I went for 500mAH and it seems to work fine so far.I was afraid the higher types could overload..
  • Mir Ali Khan
Look at Murdos solution to the problem, He is right, I just cut the plastic away enough to make contact with the sneakley (and unneeded) contacts and it works fine charging away like a good un.
Thanks Murdo, wouldn't have spotted them without your help
Posted on Aug 29, 2009
I wish I'd come here first for the answer.
Just cut off the bottom 3-4mm of the plastic from the flat end of your new replacement rechargeable AAA batteries and they charge as they should.
Shame on you Philips!!!!
Posted on Aug 25, 2010
Wakiwaki and Murhdo have the right solution - just make sure you peel off all layers of plastic, energizer batteries have a separate layer of transparent plastic below the printed layer of plastic nearly missed it. Sound still only coming out of one head phone - they are going back to Argos!
Posted on Nov 13, 2009
I just bought 1000 mAh AAA's for my headphones, but when i tried to recharge them through the headphones dock/base nothing happened. After reading a few comments here i too cut off the plastic at the bottom (-) end and they charge now. very simple, thanks guys.
Posted on Jul 02, 2011
Bad news I am afraid Alan, they are available but cost an eye watering £11.50 each!
I am using two ordinary AAA batteries (Duracell) and will just put in new ones when they run out - it's much cheaper.
If you still wish to purchase the right ones they are available here:
http://www.dutchwest.co.uk/acatalog/philips-sbchb550s-aaa-nimh-rechargeable-battery.html
My opinion of Philips has been badly affected by this use of special batteries in it's product, it would have been much more user friendly to have fitted ordinary rechargeable ones.
Best of luck,
IkaMega.
Posted on Apr 30, 2009
  • Aad Vogel Sep 18, 2010
    Hi People, What a wonderful simple solution. Tried all over New Zealand to get new batteries no luck, they still sell the headphones offcourse, almost felt tempted to to take the batteries out of the box. They are available in England 17.85 pound plus postage,or Holland 11.55 euro plus. But thanks to you I.ve turned 2 1100 mah rechargeables into what I needed, so many thanks to Murdo.
  • ocl4 Oct 16, 2010
    Well done everyone you just saved me a fortune. Wish i had looked at this page before i spent all day running about for batteries that didnt work!
  • 4 Answers
Just do what I do. Ignore the charging setup for the headphones. Use your own rechargeable batteries (or disposables). AAA is AAA and so any batteries will work.
I like the headphones and quickly worked out that the charging setup was cumbersome. Forget it and use your own batteries.
Posted on May 16, 2009
  • 2 more comments
    i tried cutting the plastic off the end of some duracell AAA batteries and installing them into my SBC HC8445 headphones. Seemed to work fine at first but then the thing heated up like crazy..had to take them out before it melted all the plastic away (some slight melting did occur)
    help.....
  • 247cookie Jan 07, 2011
    You can only use NiMH rechargeable batteries!
    Yes the normal ones'll work fine but you cannot charge them on the base station as this will heat them so much that they'll melt and/or catch fire.
    Be careful how you read other people's posts.
    It's much more cost effective to use rechargeable batteries in the long run.
  • sulla123456 Jan 16, 2011
    Thanks 241cookie for the quikc reply. I have just bought some Energiser AAA NiMH rechargables to see if they work.
    Regarding using the normal batteries, funny thing is it heated up without plugging it in to the charger! in fact it heated up without even being switched on!
    Anyways I'll try with the NiMH and see if that works.
    Thanks
    Sulla
  • alex
    alex Dec 25, 2016
    you are the man!! thank you so much saved me 13.76 euro works perfectly screw philips!!
    New Friend:
Batteries for Philips wireless  headphones - bc5bdb82-369e-4493-9872-b006e71e3bce.jpeg
Good luck
Posted on Aug 04, 2013
  • Megalome Loddarios Aug 04, 2013
    Good luck
    You need ? Is to trim the standard rechargeable AAA batrie
    and use is possible ....
    That's what I use and lasts longer charged !!!
    Good luck
    New Friend:
Hi Sanik lr3 550ah aaa rechargable in the Telstra Thub2 work perfectly if the plastic is peeled from the negative end available on ebay
Posted on Nov 28, 2012
    New Friend:
    Problem Solver:
I was about to throw my headphones in the bin till i read this i will never buy philips again
Posted on Dec 07, 2014
  • robbie pickett
    robbie pickett Dec 07, 2014
    i was about to throw my headphones in the bin till i read this i will never buy philips again
    New Friend:
When recharging aaa phillips batteriesin my headphones,do I have to turn the headphones OFF or ON whilst recharging?
Posted on May 08, 2013
By the way, my headphones are JVC HA-W600RF wireless 900MHz headphone with a 164 foot range.
Posted on Oct 25, 2011
  • William Bottger May 08, 2013
    Head phones must be powered off while charging.
I just wrapped some al foil around the negative end of the battery and folded some of the foil against the flat end. works fine and it is easy.
Posted on Oct 01, 2011
  • William Bottger Oct 25, 2011
    Don't Panic, Friends.
    Yes, I thought that would work also. I went ahead and peeled the plastic off bottom edge of two new 800 mAh Ni-MH Sanyo eneloop batteries I bought from Amazon.com. Claims on package that they can be recharged 1500x and less than 4 cents per charge. The headphones sound great and the charging light is now lit.
    I am a happy camper now.
    New Friend:
Thank you it works perfectly you saved me 13.76eur!! screw philips
Posted on Dec 25, 2016
    New Friend:
Or if you dont want to peel your batteries you can open the headphones and solder the yellow and the red cable together.
If I understand it correctly if you use "standart" batteries without the peeling, the phones will work but you cant't load them and you loose some voltage on the diode which is for reverse current protection.
charger---- v ...........|----v
power(-)---[battery}-(>|)-[battery}----(+)power/charger
Solder it like that
charger/power(-)---[battery}--[battery}----(+)power/charger
and you can use normal batteries without voltage drop.
PS:If you do the soldering dont put the batteries in reverse xD.
Posted on Jun 07, 2015
SOURCE:
Any batteries involved?
Wireless headphones would have batteries of some sort--either ordinary batteries or rechargeable. Headphones with wires probably are powered by the unit it is plugged into.
Mar 26, 2016 | Audio Players & Recorders
Thank you. I have just removed the end label of my Energiser rechargeable batteries & inserted into my Phillips Headphones & they are working just fine.
Jun 08, 2012 | Philips (33-01-031) Headphones
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
Have Philips wireless headphones SBC HC 8445. Batteries appear to be charging and there is power. Works on left side but no sound on right side.
The speaker on the right side of the headphone is dead and shorted or might have lose wiring requiring repairing like resoldering or just tapping on the right on the right side it headphone might work.
Mar 21, 2011 | Televison & Video
My problem concerns my new Philips SBC HC8445 wireless headphones. After using them for some time, the sound starts to cut in and out. First I thought it was because batteries were running low, but after...
after NiCd batteries are recharged many times they develop a memory and will not maintain a charge past the time that they were again put on the charger. If this doesn't make sense, do this: buy new batteries and install them, and keep the old ones for spares
Mar 20, 2011 | Audio Players & Recorders
How do I replace the batteries in the philips sbc hc135 headphones
i got a problem too with my SBC HC 135. I never use it before, i found it in my brother's cabinet. I tried to connect the adapter (which is have 5(if im not mistaken) red lights) to the socket. and all the lamps are lit. then i tried to turn on the headphone, but the lamp is not lit. i got a little confuse about how to use this thing. What should i do?
Nov 06, 2010 | Philips SBCHC130 Consumer Headphones
I have a philips sbc hc8412 and its not charging anymore
I would like to change the batteries but how can I get access to them?
Aug 09, 2009 | Rio Audio Players & Recorders
FM wireless headphone batteries not charging . Green light does not come on at all. Red light comes on sometimes.
you need to replcae the charging pin of your head phone, it is having loose connection............
Jun 20, 2009 | Philips (33-01-031) Headphones
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
Dec 01, 2007 | Philips (33-01-031) Headphones
Philips (33-01-031) Headphones Logo
30,367 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
