Charging & Starting Systems for Kia Sportage Logo
Anonymous Posted on Aug 08, 2013
Changed battery and altenator but my kia 2000 sportage still won't hold a charge
Steve
Level 3:
  • Kia Master 3,290 Answers
  • Posted on Aug 08, 2013
Steve
Kia Master
Level 3:
Answers
3290
Questions
Helped
1128186
Points
12184
The battery is charged by the alternator. With the engine running, a voltmeter (not a test light) should be connected to the (+) red lead) and (-) (black lead) post of the battery.
Expect to see the meter indicate 13.5 to 14.5 Volts DC. If you see LESS that this voltage, the alternator is not powering the car's electrical & ignition systems and not charging the battery. The battery is doing all the work, and it will be drained in a fairly short time.
This can be the result of a defective alternator, poor or incorrect electrical connections, open fuse, open "fusible link", etc. Until 13.5 to 14.5 Volts DC is present at the battery post while the engine is running, the battery will NOT be charged.
The battery should have slightly more than12 Volts DC available with nothing connected to it. If it is less than 12 Volts with nothing connected, it is discharged. If it is 10 volts or less, it is completely discharged and may have a shorted cell (even if new!). Either way, the battery should be charged with a home charger, trickle charger, or even connected to another car to be charged. The length of time required is determined by the level of discharge it was in when tested. When the battery is at 12 or more, it is considered charged and can be reconnected to your car. Perform the voltage checks again with the engine running.
Kia sportage shift
When you had the tranny fluid flushed, did you have them do a tranny service? This means they remove the pan and replace the filter, flush it and then refill. They also clean out the bottom of the tranny pan where all the yuck settles. My GMC products also have a magnet charged filter in the bottom to attract and hold fine metal particulates.
Just replaced battery....
take your car to a autolect
because you draw more current as what your altenator can charges let him test your altenator it must charges at 13.05 volts
My radio says hold after we changed the battery. why?
the hold means you must put in the anti-theft code on the radio. To do that you must pull radio ,write down serial number of radio take that number to kia dealer, they can look it up and give you the code to get the radio working again.
It doesn't start turns over very slowly. replaced starter and fuse. this is a 2000 kia sportage
go get battery tested and alternator . advance autoparts autozonen free of charge
My 2000 Kia Sportage imobilizer has come on and I do not have a code number "adhering" to my key as it says in the owner's manual. What should I do?
I tried to start the KIA this morning. - It was barely turning but not starting. obviously, there was a weak battery .
I used a set of jump leads and charged it up -and it started!!!!!
JOB DONE.
2answers
2000 kia sportage charging.
hi check the main alternator charigng wire the comes out of your alternator see if it is sending a 14v no less reading on a multimeter if not replace the alternator if so go to your battery see if the multimeter readings are the same as the alternator if so do a battery discharge test if not trace the path of the main wire which comes from the alternator to the battery for breaks and all connections yates210456
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
