Question about Tascam Quantegy 120 Minute Digital Audio Master for DA-88
DA-88 tape problem
I received a DA-88 tape for a project I am working on. It is SMPTE, 29.97df ,48kHz. It will not play. I shows like a blank with no movement on any tracks from the led display. It was converted from a PAL master. Could this be causing the problem. Thanks
    Problem Solver:
  • 6 Answers
Seems like you have a blank tape there.
Posted on Aug 16, 2009
Can i replace the plastic cog like wheel on my nutripro 1000watts blender as it disintegrated this morning when I turned it on?
?????????? ?? ???? ? ??? co2 ???? ??????? ?? ????? ?????? ? ???? ?? ????.
Jul 31, 2017 | Blenders
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
My DA-T500 is stuck on Tape and wont change to turntable or radio
You might have a gummed up switch. Try some contact cleaner and go from there.
Apr 29, 2012 | Computers & Internet
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
The red error light keeps coming on, with accompanying unpleasant noises on the track. I've been using a da-88 cleaner tape to temporarily fix the problem, but am afraid i'm using the cleaner too often
The cleaner tape is only supposed to be used after 50 hrs of record /play time , if you are using your cleaner tape alot , you are damaging the helical scanning head and wearing out it,s sensitivity ,
Users have found out that the cleaning tape is like sandpaper made to remove metal particles left behind everytime you run your high 8 tapes , The best way is to send it in to a authorized tascan repair shop in your area , don,t worry there,s always some shops that can be found in your area , they will do a bench test for around 45-50 bucks and tell you what if anything it will cost to fix your problem ! if it turns out to be a dirty helical scanning head they will clen that with 100% alcohol and test it , that they can do usually for the price of the bench test since they do have to remove the cover to see whats going on under the hood! , well the red error light on my machine does come on sometimes when my 2 machines are out of sync, but with shutting the unit down and starting it back up usually takes care of that the way how often do you use the cleaner?..most da-88 users are totally affraid of even using them !, good luck and if you have any more questions please feel free to email me> glenn
Jul 16, 2009 | Tascam HHB DA30 Tape for DA-88
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
I push the tape into the Vcr it tries to play it then it simply ejects it after about 5 seconds.
This is a safety feature of the machine. If it does not detect tape movement, the unit will shutdown and eject the tape.
Apr 17, 2008 | Televison & Video
Da 38 8 track audio
This is a nice DAT recorder for its time. This unit uses a drive gear system for the FF, RR and the take up reels. Try the ff and rr, if they work, I am quessing there is a bad take up idler clutch assembly.l If the ff and rr does not work, the drive belt(s) are most likely bad. Good Luck
Jun 23, 2007 | Tascam DA-30MKII
Electronics - Others Logo
125 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
