SOURCE: difference between the cadillac escalade and the cadillac esv
the esv
is longer 16'', longer wheelbase and 21" in length
SOURCE: 2007 cadillac escalade... Onstar disable
you can remove the fuse however you will get a call asking if everything is okay.
SOURCE: Cadillac Escalade
i had the same problem u need to take off and clean the throttle body and it clears right up
SOURCE: programming 2nd key, 2007 escalade
The correct procedure is to put in the original key to the On posistion.
Remove and insert the second within 10 seconds. Turn to the On. Wait like 7 seconds. Then remove the key, reinsert to test.
The key (no pun intended) here is to wait for the security light to go out.
Put in your original key or the one the car already knows. Wait for the light to go out (the little car with the padlock) and then turn the key off, swap in the key you wish to program, then wait again for the security light to go out. You are done.
Testimonial: "thanks for the info, advice was right on.."
