SOURCE: Airbag light indicator: Jeep Grand Cherokee 1997
there are many sensors and and each airbag have sensors so you will have to get it scanned to know where to start. just a note air bag parts can be very expensive so check out your local salvage yard. they can save you hundreds. good luck
paul
SOURCE: CAN YOU TELL ME HOW TO USE A SLIM JIM TO UNLOCK JEEP GRAND CHEROKEE LAREDO. LOCKED KEYS IN CAR.
a slim jim is not a good ideal to be using in todays cars and trucks with airbags everywhere and wires inside doors..call a pro and if he pulls out a slim jim send him packin...there a re far better tools to use than a slim jim
SOURCE: 1996 Jeep Grand Cherokee Laredo starter
This means it is the solenoid. But usually on those the starter and solenoid are one unit. They can be purchased individually, but it is usually almost as expensive as replacing the whole unit.
SOURCE: 1997 jeep grand Cherokee laredo hesitation problem
You should add a rs4 performance chip or the fuel economy chip also made by rs4. there like 70 bucks. If the problem is electrical changing your chip could solve the problem. Even if is doesnt work the chip will make your truck idle more smoothly, have better throttle response, and you will add 3-7 mpg. I bought one for my 1997 jeep grand cherokee straight six, and it felt like i was driving a different truck . It mae that much of a difference...you cant loose!!!Like everyone says , it could be a vac leak or a clogged fuel filter , soetimes bad gas...your problem is a needle in haystack. Try the chip...I hope this helps
