Check your Power Supply Unit..(PSU) It has most probably "Faulted".
BUT first remove all cards... disconnect all Hard Drives, CD/DVD's etc.. try to power on... if still no-go then ya PSU IS Definitely faulty. Replace.
If it DOES go, then, simply plug in each removed device and turn on again, in turn,... until it will NOT power on & that device, will be your "Faulty" bit.. replace that device/card etc. & NOT the PSU.
The PSU's are fairly inexpensive these days.
To replace ya PSU, open up ya PC... Disconnect the PSU's Plug from Motherboard. Unscrew the Four (4) Screws from PSU, from the rear, near fan.
To install is simply the reverse process... Screw the PSU into place..connect up the Plug onto the Mother Board.. ya done.. Power On.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
TSS corp cd burner stopped working TS-H292B errow code 28 how can i get it working, wisard can't...
(More)
TSS corp cd burner stopped working TS-H292B errow code 28 how can i get it working, wisard can't find hardware
my cd burner stopped working TS-H 292B code 28 wisard can't find on computer how can i get it...
(More)
my cd burner stopped working TS-H 292B code 28 wisard can't find on computer how can i get it working again
