SOURCE: Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
SOURCE: Can not determine if this program will run on Windows Vista 64bit
Sounds like Compatibility Mode may help.
To configure the compatibility mode for an application, just locate
the installation directory and right click on the .exe, selecting
Properties from the menu.
Select the Compatibility tab:
You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to
disable the visual themes and desktop composition, if you can't get
things working. If you are trying to run a video game, you will often
need to choose "Run this program as an administrator". You'll have to
play around with it, but most likely you can get your application
working this way.
Good Luck
SOURCE: Is my Family Tree Maker
It is not with Home Premium. You need to upgrade to Windows 7 Professional
SOURCE: I have a broderbund family tree maker version 10
You can read this thread from Fixya.
Hope it helps.
