Question about ASUS P5P800S Motherboard
Won't boot no display
First there will be no display so I restart it after a few min. ang Ok again it happen many times so I change my power supplyfr. 350 to 500 watts then it still happen so I think maybe it is a virus so I format my computer but it also happen so my suspect was the viseo card but when I test it to another computer it is working also the memory is ok. So The mother board now is the only susupect. I was looking for a circuit diagram ang guide to trouble shot this mother board if you can help me also how to repair this board and the possible defect. I am a cellphone tech. Hoping for your immediate assistance thank you.
  • 1 more comment
  • Spyke29 Nov 17, 2007
    my processor is Intel Pentium D 2.80ghz.i can't finish installing Windows XP Professional Service Pack 2.is there any update bios for Pentium D 2.80ghz processor support?
  • Anonymous Jul 21, 2008
    No display, processor fan is running, power supply is good, bios battery is new, my RAM and video card are good, when i checked my motherboard below memory slot i saw this, i don't know what to call this small black square shape "APM2054N (WH2EH)" look like it was leak...
    Question:
    1. what to call to this small black square shaped?
    2. Could this motherboard still be fixed if this small black square shaped is really causing the problem?
  • Anonymous Aug 31, 2008
First there will be no display so I restart it after a few min. ang Ok again it happen many times so I change my power supplyfr. 350 to 650 watts then it still happen so I think maybe it is a virus so I format my computer but it also happen so my suspect was the viseo card but when I test it to another computer it is working also the memory is ok. So The mother board now is the only susupect. I was looking for a circuit diagram ang guide to trouble shot this mother board if you can help me also how to repair this board and the possible defect. I am a cellphone tech. Hoping for your immediate assistance thank you.
Posted on Aug 31, 2008
Try to inspect your motherboard closely mostly your capacitors and and semiconductors should in good shape: no leak etc...
Posted on Jul 21, 2008
    Problem Solver:
  • 4 Answers
Have you change the memory. try to change it with a pqi brand.
Posted on Sep 03, 2007
2 Suggested Answers
6ya staff
SOURCE:
dlundmark
Dave Lundmark
  • 797 Answers
SOURCE: restart
Hi:
Test your memory.
Check one stick at a time and use a program such as memtest86 free for use. http://www.memtest86.com/
Memory can cause these problems.
The mother board could be the problem.
Try another display card in one of the pci slots. See if the display will work that way.
If the internal display is not working right, you may be able to turn it off. Or just use another video card.
take care,
Posted on Sep 02, 2008
Dell E6400 won't boot up (most of the time)
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 11, 2013 | Dell Latitude E6400 Laptop
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
Block out po ung moher board ko ano po ang pwede ko pong gawin tnx po
Hello
Kung walang power yung motherboard niyo as in ala power check niyo yung power supply kung ok ang power supply, at may power yung motherboard niyo pero ala display sa screen check niyo memory, kung nag be beep siya ng three times video ang sira niya.
Good luck
Jul 11, 2011 | Computers & Internet
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
MY CAR GOES INTO LIMP MODE WHEN I RESTART CAR ITS OK THEN FEW MINS LATER IT HAPPENS AGAIN I CHANGED AIRFLOW MASS METER I TRYED IT GOING FAST AND SLOW BUT IT STILL HAPPENS NEVER WHEN THE CAR IS COLD MANY...
You may need to change your thermostat or coolant temp sensor, If the sensor does not detect proper temp than this could cause ur problem.. A scan tool could help give u the readings.
Oct 09, 2010 | 1997 Audi A4
Asus p5kpl-cm boot problem
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Aug 02, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
Restart
Hi:
Test your memory.
take care,
Aug 31, 2008 | ASUS P5P800S Motherboard
Open Questions:
See all ASUS P5P800S Motherboard Questions
ASUS P5P800S Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
