Are you sure you're pulling the correct drain plug?
On Harleys with the oil tank under the engine, there are usually two drain plugs, oil and transmission drains.
Also, some have a drain on the bottom of the engine, which only a little residual oil will come out of it.
Finally, when the oil stops draining from wherever you're draining from, does the oil dipstick show that the oil level has dropped?
If not, you got the wrong plug!
SOURCE: oil drain plug
Follow the hose that goes to the frame from the oil tank. Loosen the clamp and pull.
its not a plug its a hose look under the tank on the pipe side, look for the hose thats goes to the bottom frame rail (tube) thats the drain hopes this helps
Hi
It is located on the right side just under the oil tank ; if you follow the rudder hose that exits the rear right side of your oil tank it leads to the bottom of the frame under this is the oil plug. This hose has a plug clamped to the end of it or stuck into a prug that is welded to the frame.
After this unclamp and pull the plug to make sure that you have the dipstick out before pulling it loose.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
SOURCE: oil drain plug 2004 harley dyna wide glide
your oil drain is on the right side pipe side of your bike look under near the rear back part of your frame you will see a plug with a one quarter allen key threaded plug style bolt kinda hidden in bridge plate of frame it is flat in conjuction with line on bike it is in area right behind where your back pipe expands to baffle of pipe where its skinny and then gets bigger its the one closest to you
Its at the back of crank box right hand side of bike attached to bottom of frame in a sprung clamp just before the softtail swingarm- black hose with a plug and hose clip
