Question about Hannspree HANNS?G HU196D Monitor
Hy all and thankyou for read this! I have a
Hy all and thankyou for read this! I have a HANNS.G HU196d 19" monitor . Sometimes after 1/2 days or some hours , sometimes after 1 minutes shows me 1 mesage on my screen "Adjusting..." it`s rlly painfull , i have ATI RADEON HD 4350 video card connected with a HDMi cable and windows 7 / 32 bit. I wanna stop/disable this auto adjunsting or find the problem . Thankyou.
    Top Expert:
  • Hannspree Master
  • 12,962 Answers
Go to your run command and enter msconfig and hit enter. then > startup and in the listing of items un check the line that has anything to do with your video card/software.
Posted on Sep 08, 2017
SOURCE:
SOURCE: cannot find drivers for product.
Hannspree said that there is no need for a separate driver for XP and suggested I check for an updated driver for my old NVIDIA Video card... That was the answer. I now get the full 1400X900 resolution.
Posted on Jul 11, 2008
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
SOURCE: monitor won't stay on
Hey. This problem is caused by the Backlight bulb(s) blowing up.
This is fixable. You have to get into the monitor and remove the LCD screen to see what bulb you need. This is a moderately difficult job and fragile parts will easily get broken.
However by all means have a go but this is the problem that you guys have been experiencing
Gareth162
Posted on Sep 02, 2008
asthanarht
  • 258 Answers
SOURCE: My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Posted on Jul 03, 2009
pravinbhavsa
  • 348 Answers
SOURCE: Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Posted on Apr 19, 2010
Screen keeps displaying "adjusting...."
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
How to get rid of main menu on my monitor dell 1900fp
press the menu button again or wait it out - it goes off by itself after 20 seconds of inactivity
Apr 07, 2014 | Hanns.G Corporation HU196D (Black, Silver)...
Monitor suddenly on the blink
Dear Sir,
It is not a problem power supply this problem is base plz exit IC And clen after re-install IC And proper soldering
Jun 13, 2013 | Hanns.G Corporation HU196D (Black, Silver)...
Blue vertical line appears down left hand side of screen. I thought "dead pixels" but sometimes the line is gone and the screen is back to normal. Any ideas would be appreciated. Thanks, John.
It will be one of two things, the video cable from the computer to the monitor, if you can detach both ends, sub another cable, failing that the problem lies in the main board that is attached to the LCD panel and where the video is processed and viewed on the display. Unfortunately to repair this type of problem will exceed the amount for a new monitor.
Feb 17, 2011 | Hannspree HANNS?G HU196D Monitor
Hi...Hannspree hu196 ,screen is blank but front light is on and goes green that it detects computer. Chris
this looks like the backlight has gone in your monitor, to test this connect this monitor to your pc and wait for green light. get a torch and shine it into the screen (really close up) you might see the log in screen.
To fix would probably cost more than the actual monitor is worth, would suggest going online and getting a cheap replacement, loads of them are listed on online auction sites.
D.
Oct 22, 2010 | Hannspree HANNS?G HU196D Monitor
Please tell me where find drivers for my monitor "Hanns-G,HU196D" i dont find this. Please send me or write me links directly. Thanks and good luck.
Monitors don't need drivers, video cards do. You will need to find out your exact model of video card by running this program:
http://www.piriform.com/speccy
then go to the site of its manufacturer and you will find its exact driver there, in the Downloads section.
Oct 05, 2010 | Hanns.G Corporation HU196D (Black, Silver)...
Hanns-g hc 194d 19 inch monitor
I am already registerd and have my unlock number,but I have forgotten my password so I need new password
Aug 25, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
OSD IS LOCKED AND WILL NOT UNLOCK! MODEL IS .....HANNSG HU196D
hey, to unlock osd press and hold the volume down "<" the volume up ">" and "menu" all at once then the osd will unlock
May 27, 2009 | Hanns.G Corporation HU196D (Black, Silver)...
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hannspree HANNS?G HU196D Monitor Logo
114 people viewed this question
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
