Question about Danby DPAC8020 Air Conditioner
EVerstar Portable A/C
Hi there, My unit worked fine for a year.. this year the extra heat hitting california forced us to use it on most of the time. Now the unit just keeps turning on.. 2-5 minutes later then the cool option shuts off for 2 minutes then comes back on again. This is the 8000 BTU MODEL ..i cleaned everything inside.. I read that the thermostat could be the problem or the antiheating coil (not sure what) could be it also. Is there something I can try myself to unplug or change to fix this? Or is the AC unit just ready to die?
  • 1 more comment
  • jelatinas Jun 02, 2008
    Hello I have the same problem as yours. The compressor works for only 2 minutes and then shuts down, only the fan is working...then after 2 minutes then compressor comes back on again. Were you able to find a solution for this?
  • tektek Jun 09, 2008
    You know.. from what I've figured out it was a wattage/power problem.. too much overload affected the unit powers supply .. when I hooked it to a completely separate power line it worked fine. Hope this helps.
    Hi, from what I could figure it was a power/wattage problem. When I hooked it into another separate power line via long cable.. it worked with no issues.. so I guess the unit wasn't getting enough power due to other devices being on the same line.
    Hope this helps.
The AC will not stay on pass a few seconds at a time and will not program also I cannot find the remote
Posted on Jul 18, 2010
I had the same problem. Ran for about 2 minutes then turned the compressor off for 3-5 then ran the compressor again for 2. I noticed that when just the fan was running it was blowing pretty warm air too. I started looking it over and noticed that when I put the vent back in the window that the extension was covering the hole. IE I put it in backwards so I was covering the airflow hole to the outside. Changed that and it works fine now :) Check your vent line and make sure it isn't clogged or covered some how.
Posted on Jun 17, 2008
I have the same problem how can i solve this problem>
Posted on Jun 09, 2008
Is there a tube in this unit that forces the water to the side bucket
They have a hose inside that could off undo the back and have a look.
Aug 13, 2014 | Everstar Portable Air Conditioner Everstar
Everstar Air Conditioner Portable has power to unit but screen is blank, no fan or cool!!
make sure you have power to it, try using another plug if not it sound like a bad board, the boards and screens can be ordered and replaced
Oct 22, 2013 | Everstar Portable Air Conditioner Everstar
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
I need a exaust hookup for my everstar mpk10 cr portable ac unit
The unit should have the end that puts out the heat vented to the outside . Is this a windoow unit?
Oct 01, 2009 | Heating & Cooling
Everstar portable ac 10000 btu
The everstar 10,000 BTU unit will require a dedicated 115 V 15 amp circuit. if there are other things pluged into outlets and running from the same breaker then the 15 amp breaker will trip. Or, these units also have a GFCI plug adapter. Be sure it has not been tripped due to an improperly grounded outlet, or wet location.
Aug 22, 2009 | Heating & Cooling
Don't know how much water to use
Do not put any water in the unit, the water that is in the unit drawer or bucket that is attached to the hose is a byproduct of the air conditioning process.
It transfers heat to cold and in the process produces condensation = Water.
May 30, 2009 | Everstar Portable Heater/Fan
Hi fdisc I feel quite sure your compressor is going straight to ground you need to get someone to check the comp, for its resistance and he or she will soon let you know for sure.
May 24, 2009 | Danby DPAC8020 Air Conditioner
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
probably, the p1 signals that the water pan is either full or not sitting properly. There is a small lever that it pushes when the tray is pushed in. It is a switch that might have pushed out of its housing. Mine had and I had to dissasemble the unit to get the switch back in place, then it worked fine. Good luck. Dean
Aug 06, 2008 | Office Equipment & Supplies
Everstar portable air conditioner
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
465 people viewed this question
Top Danby Heating & Cooling Experts
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
