Question about Toshiba 42H81 42" Rear Projection Television
Red is out of convergence
The red line is offset and cannot manually move it using the remote. Using touch focus button give touch focus error. REpair man says it going to cost $560 to repair. He say's the Digital Convergence module needs to be replace and there is no easy way to replace it.
    Problem Solver:
  • 24 Answers
Replace the conver. IC'S
Posted on Sep 03, 2007
SOURCE:
"touch focus error" appears when the test is completed. There is a double effect showing on the pictures and the words. What can be done to fix this?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Toshiba 65HDX82 65" Rear Projection...
The screen looks as if it is 3D. The colors are all offset.
  • Screen looks 3D
May 31, 2010 | Sony KP-57WS500 57" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
You can repair it yourself by replacing both STK392-110 Convergence ICs. You can get replacement ICs at the following link with free instalation instructions . Heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | Toshiba 65HDX82 65" Rear Projection...
These sets use STK392-110 voltage amplifiers in the convergence circuit. Chances are good that these are causing your problem. It is best to upgrade these to STK392-150. There may also be some low tolerance resistors that have gone off value. I do not suggest, however, that you do this work yourself unless you have some electronics training. Find yourself a good technician that does component level repair and not board level. The labor will be higher, but the parts will be significantly lower.
Aug 05, 2008 | Toshiba 50HDX82 50" Rear Projection...
I would stay away from that repair man. That model has just one Convergence IC number STK393-110 and it takes about 45 minutes from start to finish to remove the old IC and install the new one. You can get the replacement IC at the following link and they provide free instalation instructions with pictures so you can do the repair yourself for less than 30.00. Heres the link. You need just 1 STK393-110 Convergence IC they have free shipping as well.
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
