Question about Freezers
Master-Bilt Freezer doesnt cool enough
I have a Master-Bilt walk-in freezer. The temperature is supposed to be at -10 degrees. The freezer will start but shuts off at 0 degrees and will not cool down enough. The compressor runs hot. Please help.
If the temperature drops to zero and no more (water freezing point) - could be that there is moisture in the system and this freezes at zero degrees blocking the expansion valve (valve where the pipes join at the inside coil). If this is the case you will need to get a refrigeration technician to open up and help you.
Dale
Posted on Dec 07, 2007
    Novelist:
  • 87 Answers
The only thing I could suggest is looking at the evaporator (inside coil / cold bit) and making sure it is not frozen over reducing the airflow through the coil. If it is then put it onto a couple of defrost cycles to clear the ice build up. Not sure exactly of this type but would assume you also have a sight glass on the external unit, you can check this to see if when running the sight glass is clear (fully charged). Another check is looking at the compressor and the larger of the two lines (suction) should be cold back to the compressor (this line is normally insulated). However I would suggest your best course of action is a good refrig. techy. Hope this helps.
Posted on Sep 04, 2007
6ya staff
SOURCE:
FREEZER NOT COOLING
what is your model number is then we can get started then
Jan 10, 2013 | Traulsen Trauslen Reach In Freezer
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Feb 21, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer cooling doesn't come on, just the fan comes on. please advice. thanks
http://www.master-bilt.com/pdfs/io_manuals/gt_50_60_80_io-2-21-07.pdf
Go to this web site and get the manual for your freezer. check out the trouble shooting section and the wiring diagram for your unit. If you are still having troubles, get back to me.
Jan 22, 2010 | Master Bilt 25.5 cu. ft. Freezer GT80
Hi,Ihave had my electrolux fridge freezer for two years now and it is sited in my garage.When it gets really cold the freezer turns off defrosting everything,just found out if it drops below 10 degrees it...
Good day,
Not really. Domestic refrigerators are designed to operate in an environment where people live.
Most all manufacturers recommend that they not be placed in an area that goes below 55 degrees.
At any temperature below that it starts to degrade.
Cold enough and it will not work at all.
The reason is once the fresh food compartment reaches it's normal temperature of 33-37 degrees, it shuts the whole machine off.
That is by design, on any refrigerator like yours that has only one compressor and cooling fan motor.
As well, there are other issues. In that situation, the machine could well stay off 12 to even 24 hours.
The compressor has an oil sump in it, and the oil becomes very thick. When it finally tries to start, it creates a very stressful situation for the compressor, and could substantialy reduce it's life.
Jan 17, 2010 | Freezers
On our walk in freezer, the closer at the top is lesking fluid
I would seriously consider replacing it, it is probably worn beyond repair.
Good Luck.
Gilshultz
Dec 02, 2009 | Master Bilt 95 cu. ft. Commercial Freezer...
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezers Logo
193 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
