Question about RCA HD52W59 HDTV Projection Television
My RCA My wide screen will not come on and smells a llil burnt as if something had blowed. What do you suggest the problem is. I have had it for 2 years and it have not watched it that much.
    Problem Solver:
  • 24 Answers
The TV need to be inspected for dignostic.
Posted on Sep 03, 2007
SOURCE:
No heat blowing from vents
probably your blower motor resistor has fried, not an expensive fix ath a garage
Dec 08, 2013 | Chevrolet Impala Cars & Trucks
I have a HD52W55 and it will not come on. heard a pop and smelled something burning, took the back cover off can not find anything obviously burnt but have no lights and no power.
Well, my first guess would be a blow fuse, did you check for that?
But if you smelled something burning, then even if the fuse did blow, it failed to protect something; probably the main power transformer. That's a coil of wire in a sort of square shape that should be near the fuse. Its hard to tell if they're burnt sometimes, but it may need replacement.
Please upload a few pictures so we can have a look too.
Mar 25, 2010 | RCA HD52W58 52" TV
PT5299HD My big screen was on for about 2 hours. The picture was great and then, suddenly it had a bad electrical smell and a blurry screen. Any Ideas?
You are in need of electrical service. Hopefully it has a warrenty. To many possible causes to guess, but the burnt smell, suggests a qualified technician should repair this for you. Good luck.
Jul 07, 2009 | Televison & Video
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Honda Stream bad smell from air cond
Seems like something fell into the air system. Try replacing the cabin air filter.
Apr 05, 2009 | 2001 Honda Civic
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
RCA Televsion Stopped Working
its gone. electrical smell, like burnt? thats how we electricitions check for problems in the field. :) means something overheated or shorted. Easy way of telling, no tools required.
Oct 16, 2007 | RCA F35755MB 35" TV
Big screen RCA
Bad flyback ? P46921YX1 = part # 239111.................
P46921YX4 = # 250694..............................T.
Sep 18, 2007 | RCA P46921 46" Rear Projection Television
To Arpi > PS2 U.S.A. version (110 volts) SCPH-39001 charged to 220 volts - is it burnt already?
This would have damaged the power supply, most likely not harming any other parts. Fuses do not smell when they blow so something else was damaged. I would suggest looking for a similar revision that has a blown laser or other trouble and use the power supply from that.
Jun 02, 2007 | Sony PlayStation 2 (PS2) Console
Tv blew up
You probably have a bad hv splitter module i would recomend calling a reputable shop in your area as there are dangerous voltages present.
Sep 16, 2006 | RCA P46924 46" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
