Question about GE JGBP33 Gas Kitchen Range
Oven not lighting
GE oven will not light. The display is working and the broiler works as well. When the oven is "on" I do not smell any gas though. I tried turning the oven on and lighting it with an ignitor, but nothing happened. Any suggestions.
  • 3 more comments
  • tedrush Jan 14, 2008
    I have the same problem. The owners manual suggested checking to make sure the gas switch under the oven is on. It is.
    There was no mention of an ignition switch. Where is this?
  • gayleR35 Jan 31, 2008
    The broiler works but the oven will not. Both ignitor elements seem to be seperate (one for oven and one for broiler). Could this be a simple 'fuse' issue? And, if so, where's the fuse?
  • keepupwithus Jun 13, 2008
    Same problem. The oven will not heat up. The broiler and burners work fine. Anyone know how to replace the ignitor?
  • denadog Mar 12, 2009
    Same problem. Broiler, burners work. Oven sits at 100 degrees and no gas is heard. Igniter looks to be about $67. Is it consumer replaceable?
  • Anonymous Mar 28, 2009
    As with others, broiler works fine, stove top burners work fine, but oven will not light.
  • 725 Answers
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
SOURCE:
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Oven and Broiler not working
The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
inside the broiler drawer on the very back wall.
Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Oven & broiler not working
Please follow this LINK for your manual
Jun 16, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Feb 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP33 Gas Kitchen Range Logo
374 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
