Home | Cuisinart | DLC-8S Pro Custom 11 Cups Food Processor | Put in nuts and tur...
Cuisinart DLC-8S Pro Custom 11 Cups Food Processor
Problem for Cuisinart DLC-8S Pro Custom 11 Cups Food Processor
Put in nuts and turned to mush
By suecee on Apr 04, 2009
I only pulsed once and already had too fine chopped walnuts AND alot of unchopped nuts sat on top of blade. My first use of this processor
Best Solution
posted on Apr 05, 2009
Very Helpful)
ThaMp3Doctor
Rank: Guru
Rating: 86%, 4531 votes
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Cuisinart DLC-8S Pro Custom 11
Questions and Unsolved Problems for Cuisinart DLC-8S Pro Custom 11
Do you recommend Cuisinart DLC-8S Pro Custom 11 Cups Food Processor?
Answer
Answer
the motor stopped working i unplugged and replugged into a number of outlets...nothing happens is... (More)
Answer
Even thou plugged in, there is no response from pressing either of the buttons
Answer
We're searching for all discs for our Cuisinart DLC 7, Professional 14 purchased in the early 80's.... (More)
Answer
Cuisinart DLC-8 bowl is stuck on base, what is the best way to fix this? Or is it repairable?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cuisinart DLC-8S Pro Custom 11...:
Top Food Processor Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Food Processor Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
